The Lounge A place to talk about almost anything but politics and religion.
Funniest snake oil theories
Old 8th May 2013, 02:13 AM   #501
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by sonidos View Post
I also note quite a bit of bitterness here too!
I have an extreme tolerance for bitterness, organoleptically that is, and zero tolerance for hot as in capiscum (go figure). Also think you can't put enough cilantro in salsa.
Jacco, you didn't tell me it does not fully wash out. My pants now give me red hot knees.
"The way up and the way down are one in the same"
Old 8th May 2013, 04:02 AM   #502
CopperTop is offline CopperTop  United Kingdom
Originally Posted by fas42 View Post
I'm repeating myself here, I know, but I feel it's worthwhile countering some of the negativity - this is an update to a chap's evaluation of how his system sounds after adding lots of very expensive "snake oil": My Experiences Building a Total Shunyata Zitron System--A Paradigm Shift - Page 2.
This rings the bells for me that he's managed to break through the quality barrier, albeit through very costly add-ons. The clear message is that such level of playback is the goal, and the corollary is understanding what needs to be done to make it happen at much more reasonable cost ...
I think some of the contributors here could learn quite a lot from modest and unassuming Shunyata founder Caelin Gabriel.
I was physical sciences major in college but couldn't quite finish my degree. Money issues. I then entered the military. They don't care about credentials at all. They just test you - thoroughly. They were duly impressed with my abilities and decided to send me to a secret Navy cadre. I obtained the equivalent of an electronics engineering degree and was assigned to a military division of the National Security Agency. The NSA is the governmental information-gathering agency, with the world's most elaborate high-speed computers and signal decoding equipment. We were involved with intense R&D of ultra-sensitive data acquisition systems.
We could lock onto correlated signal virtually obscured by random noise, a feat believed impossible by engineers using commercial electronics of the day. Working on these projects and with other NSA engineers taught me that 'impossible' is a relative term - and one that is not acceptable to overachievers.
RH: What is the most effective method of judging the
performance of AC power products?
CG:
Really, no differently than you would judge electronics or speakers with a few key exceptions. Make sure you apply four to five days of current through to the power cord or power distributor, if it is new. If you are considering replacing stock cords, replace all of them at once and compare. Otherwise a single quality AC cord could merely highlight negatives or have its effects mitigated by all the stock cords in the system. Evaluate stock cord replacements as a system whenever possible. Keep in mind that a power-distribution chain functions ideally as an integrated system and not as a random accumulation of disparate parts. We design our products to function ideally as a system, so
comparing one of our power cords in a mixed system is of little value other than to judge the one cord’s synergy with other random products. Do not mix or cascade power conditioners or you will end up with a very reactive and possibly unstable power delivery system. Do not compare power conditioners while another unit is plugged into the same outlet—they interact with one another even if they are off.
How did you discover this mysterious "flooby dust"?
(Laughs) By accident! I worked with a derivative of this material for an application unrelated to audio. I unwittingly parked a bag of it next to a component and noticed how the audio system suddenly sounded better. To avoid mechanical vibration damping from interfering with the compound's effects, I then built suspension jigs so I could research these proximity results by floating bags of the substance above components without touching them.
Humor aside for the moment - the compounds are not magic or voodoo science. Their principles of operation are deeply rooted in well-known, conventional physics concepts. Actually, FeSi-1000 is a term for patent-pending compounds that, like ferrites, absorb electromagnetic fields by proximitiy, by converting them into heat withint the molecular structure.
Wherever there was a strong electromagnetic field -- above power transformers for example -- the improvements of this absorptive shielding were pronounced. Of course eventually pouring optimized FeSi-1000 into a power cord also acted as a mass damper to yield secondary benefits.
Copper has a specific sound. So does silver. Both have a certain characteristic signature that's intrinsic to the material.
Now your dielectric becomes a spice that augments this base flavor. Copper has a weighty, meaty sound that's a little soft in the highs, perhaps a little blurry or fuzzy - certain coppers can even be a little grainy. If you know what all the different dielectrics sounds like, you now carefully select one appropriate for how you desire to balance these basic copper qualities. How do you want to complement their strengths? How to compensate for their weaknesses? Then you think about the different types of connectors, the metals you want to use..
Method and product for reducing distortion in an audio or home theater cable
US 6545213 B1
Abstract
A method and product for reducing distortion in an audio cable includes a flexible outer conduit and at least one electrical conductor (i.e. wire) disposed in the conduit along its longitudinal length. A granular or beaded ferro-electric substance is disposed in the conduit along its longitudinal length. The electrical conductor is surrounded by (i.e., immersed in) the ferro-electric substance along its length and extends from each end of the cable and may include whatever termination is desired to connect the electrical conductor to a component part of an audio or home theater system. A seal is provided at each end of the audio cable to retain the ferro-electric substance. Preferred ferro-electric substances include generally spherically shaped beads of silica gel or rochelle salts of combinations thereof.
Our speaker cable is based on a unique geometry that was granted a patent about a year ago. It's probably the first truly new cable geometry in the last 15 years. It's based upon a matrix of counter-rotating helixes. It's essentially a braided cable but probably the most complicated braid ever attempted....
...The cable is composed of 8 conductors (4+4) and twin spacer rods for a total of 10 strands that are hand-braided into two spirals that wind in counter-clockwise rotation while being interlocked between the spacers. Every inch is braided by hand, every cable must be braided to length - no cutting portions off 100ft spools.
Old 8th May 2013, 04:17 AM   #503
ezavalla is offline ezavalla  Argentina
ezavalla's Avatar
Old 8th May 2013, 04:31 AM   #504
fas42 is offline fas42  Australia
Banned
Still missing the point. The goal's the key, not the means to achieving it - so, the first objective is to be able to consistently reach that goal, no matter how ridiculous or obscure the method is for doing so. Then, having established that the goal is not an illusion, some bizarre random event that can never be repeated, you can then progress to the next stages. Which are, to understand, at least to some degree, the underlying mechanisms at play, and engineer a more sensible and repeatable method of achieving the goal.
If everyone keeps falling over, laughing, while playing the man rather than trying to see a bigger picture, then no progress will be made ...
Old 8th May 2013, 05:01 AM   #505
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
Scott, if we meet up in Chicago this Fall, then let's whip up some salsa. My Mom can't take the heat so I end up making a super mild batch and a super hot batch.
Old 8th May 2013, 05:14 AM   #506
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by ezavalla View Post
... or a method to take it "out of the problem". That's your choice
Mono button?
Ears aren't microphones.
Old 8th May 2013, 09:25 AM   #507
According to that logic we would do just as well to go up to people in the street and ask them for their opinions on what would improve our audio systems, or read tea leaves, or pick random words out of the dictionary. And who said anything about falling over laughing? Have you seen something funny in the extracts I posted?
Old 8th May 2013, 09:27 AM   #508
john curl is offline john curl  United States
john curl's Avatar
Well said, Fas42. I really try to stay in the middle, mixing audio research done by others, with my own experiments, and the 'claims' of others (which can be rather extreme sometimes). It's difficult, but it can lead to more successful audio designs.
"Condemnation without Examination is Prejudice"
Old 8th May 2013, 09:56 AM   #509
Hello John. Can you give any examples where someone else's rather more extreme claims turned out to be correct, and were useful in your work?
Old 8th May 2013, 10:54 AM   #510
Banned
Don't see how you make the connection from trying to experience and understand some phemonenon, to random behaviour ... if you don't want to consider that something interesting may be occurring, or be relevant, that's fine, but for those with curiosity who come across something doesn't make sense at first glance, it may be a signal for a treasure hunt ...
Funniest snake oil theoriesHide this!Advertise here!
More snake oil astouffer The Lounge 26 6th November 2016 06:21 PM
Snake oil or not? Carlp The Lounge 21 28th February 2011 10:03 PM
Looks like snake-oil but really works. Circlotron Everything Else 18 28th November 2002 11:40 AM
Copyright ©1999-2019 diyAudio
