The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 6th November 2012, 06:31 PM   #28991
Tom Danley is offline Tom Danley  United States
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Hi jneutron, all
Ah, I see .
4W /sq/in acoustic power density would be about 158dB I think (you can do acoustic levitation with that intensity). This would be a pressure of about 1588 Pascals out of 101,325 so the pressure would be about .22psi (you can work through the gas law and temperature effect on speed haha).
The more difficult part to quantify is the nonlinearity of air is an accumulating effect. The effect goes up with intensity (because of the larger difference in the instantaneous pressure and rarefied temperatures) AND it goes up the larger the number of wavelengths it travels at that intensity making a slowly expanding horn more problematic.
In a horn, the sound is traveling through an expanding passageway and so the same power spread over a larger area means the pressure falls all the way from the diaphragm to the mouth. In an exponential shape horn, the pressure falls more slowly and so has a greater susceptibility of air distortion, at the opposite extreme, a conical horn has a very rapid expansion but also does not load lower frequency end of the same driver well. The impedance transformation part of horn operation has a “high pass” effect to it based on how fast the horn area expands. So many contradicting issues but a lot of fun to work on.
John is quite correct when he said it is almost impossible to pre-distort properly and even at that, one can only fix some things. With driver distortion, one needs a 3d response model of what it does at every frequency at every level and even then, some aspects of what it does depend on what it was been doing an instant, a moment and minutes before.
With the levitation sources, these were narrow band devices, that was the only way I could make 160dB with 20 Watts so one had little freedom with waveshape, they produced a sine wave, how much what you got was a saw tooth depended on how loud it was and how far away one was..
One can levitate with one source and a reflector but two sources producing an interference pattern allow a higher intensity where the levitation is because it doesn’t have to go to a reflector and bounce back to make an interference pattern.
A cool part not shown in the video is that if you roll the phases of both sources, you can move the samples smoothly up down (axially). At 22KHz, 360 degrees is about ½ inch motion
Regarding absolute phase and the importance of, generally loudspeakers do not preserve the phase of the input signal and spreads harmonics of a single event out in time (negating the idea of an absolute).
The real problem is that we don’t hear like we measure, a measurement microphone can precisely capture the pressure at a given point in space. WE hear through two ears that have a far from flat response, who’s pina response makes in the ear pressure measurements of our ears look broken, big changes depending on the sounds incoming angle and so on. Our magnificent ear / Brain / learned pattern system takes what makes measurements make look “broken” and instead of “broken” that is how we can tell where sound is coming from, how high it is even how far away it is. Our processing system automatically seeks to “hear through” noise and problems to get what we expect and want so we often don’t hear giant problems in a room etc, UNTIL we change something.
If you want to hear how accurate a loudspeaker is, make a generation loss recording with a measurement mic in a semi anechoic condition (outdoors on a quiet day). Like any part of the chain, the more passes it will tolerate before transmogrifying the signal, the more accurate it is.
At work, we used this at work developing our loudspeakers (large scale sound) and it was eye opening many times.. It is surprising how few passes even some good loudspeakers will last, each generation an increasing caricature of what is wrong.
Best,
Tom Danley
Danley Sound Labs
Bring back mst3k and futurama
Old 6th November 2012, 06:31 PM   #28992
Esperado is offline Esperado  France
Banned
Originally Posted by bcarso View Post
CAlso Sprach Zarathustra at Disney Hall
You have that kind of things ? I don't knew Mikey was directing symphonic orchestras...(smiley here ?)
Old 6th November 2012, 06:45 PM   #28993
john curl is offline john curl  United States
john curl's Avatar
Esperado, we are not talking about the same sort of 'listener fatigue'.
"Condemnation without Examination is Prejudice"
Old 6th November 2012, 07:01 PM   #28994
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by Tom Danley View Post
Hi jneutron, all
Ah, I see .
Yup..major stuff.
Gay-Lussac's law states P1/T1 = P2/T2, temp in absolute.
P1 = 101325
P2 = 102913
T1 = 300 K
T2 = (T1 * P2)/P1
304.7 K, 4.7 degree C rise in temp (peak)
at 300 K, sound velocity is 347.202 meters per second
at 304.7 K, velocity is 349.9 meters per second.
A column of air 1 meter long will be traversed in 2.88 milliseconds at 300k
at 304.7, it will be traversed in 2.85 milliseconds.
A shift of 30 microseconds.
A bit over 1 order of magnitude larger than human sensitivity to interaural delays for localization of an image. At the least, it will provide dithering of the hf content, which has also been demonstrated as helping human localization.
Note that 30 is slightly larger than 21. I had to borrow a colleague's fingers to do this math..
jn
ps. Note that I also neglected the fundamental distortion caused by the temperature variation. Let it not be said that I am a nitpicker..
pps. Watch out for the ideal gas law found on the web. In general, they consider the spl as low enough that there is no temperature variation, that is not what this discussion is about.
Old 6th November 2012, 07:05 PM   #28995
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
No fingernails on piano keys, no sound of lips with 30 microsecond smearing.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 6th November 2012, 07:05 PM   #28996
bcarso is offline bcarso  United States
diyAudio Member RIP
Mickey only makes guest appearances to conduct the Dukas
Old 6th November 2012, 07:17 PM   #28997
diyAudio Member RIP
Best,
Tom Danley
Danley Sound Labs
By the by, I was only proposing predistortion as applied to the narrowband levitation problem, to alleviate the sawtooth behavior, emphatically NOT for wideband audio use.
Old 6th November 2012, 07:27 PM   #28998
jneutron's Avatar
Funny thing too about those levitation sources, there is a larger configuration using 6 orthogonal sources that can produce about 175dB at the intersection.
Ummm..not to be a nitpicker or nuttin...
There is no such thing as 6 orthogonal sources in 3 dimensional space.
But I knew what you meant..not that it woulda stopped my nitpicking....
jn
Old 6th November 2012, 07:31 PM   #28999
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
I'm not quite sure what all the fuss is about the horn throat region of the horn and compression driver combination is. I see the conversation about temperature rise in the throat due to frequency and volume area but this area would seem to be the least of the problem in this regards. The initial loading of the majority of compression drivers, the rarification area lets call it, from the diaphragm to the initial slot opening is on the order of 10 to 1. This would be the area of highest temperature rise and also to any real perturbations that would affect the frequency response curves. After this point in the combination anything else is of an order of magnitude lower than the initial compression area. So why are we focusing on this area rather than the compression driver itself?
I agree with the statement that a speaker that fools you into thinking that something actually just happened in a room is a definitive plus in whether a loudspeaker combination is going to sound true to the original source. I have found myself more than once turning around to look for someone saying something on a recording before realizing that it was in the recorded playback. When something is so real sounding that it can make you jump up out of your seat we have hit the main goal of sound reproduction. How many times I have had one of my kids or a friend say I have never heard that before on a track they have heard many times before. That is also one of the things I look for. Articulation and clarity goes hand in hand with creating that magic we all call music.
Old 6th November 2012, 07:47 PM   #29000
jneutron's Avatar
The diaphram to slot ratio problem is not quite the same (however I certainly acknowledge the issue you raise as an important one. I'm speaking only of the energy density modulation of the velocity along a long throat.
At the slot, there are a few more issues. The impedance discontinuity is just downright nasty. Higher temperature rise would be defined by the orifice edges and reflection at the impedance step. The bulk of the cavity will not have higher temperatures than the throat at the slot, but I'm sure peaks will.
Might as well start the process of filing the intake and exhaust contours. Honestly, I never inspected my horns or drivers for that. Didn't matter to me.
Needless to say, I'm not gonna get any kind of numbers using ten fingers and ten toes to properly discuss slot to diaphram ratio loading and contouring..
jn
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
