Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
The Lounge A place to talk about almost anything but politics and religion. |
Thread Tools |
#4331 |
The Dastardly Dad of Three
#4332 |
#4333 |
30 white and 20 black pushbuttons, 10 by 10 mm. Will make a simple kbd for a 128 step sequencer.
From AliExpress.
/Magnus Due to economical cutbacks, the light at the end of the tunnel has to be switched off. |
#4334 |
Another bloody set of speakers.
Couldn't resist. Solid, interesting enclosure, 4.5" full range driver, $20 AU. From a decent little Yamaha micro system.
Irishman downunder |
#4335 |
they arrived !
I think it’s called “retail therapy” ![]()
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#4336 |
It’s only “retail therapy” if it’s ridiculously expensive. Those don’t seem to be, if you got them from Radio Electric Supply. What vintage are those, any indication?
#4337 |
Another batch of 50 surplus capacitors to add to the pile.
#4338 | |
the seller advert says “ SAME DATE CODES - 313 (1943 OR 1953) “
#4339 |
I’m sure it does mean 43 or 53 - but I don’t know which. Since it was an older type, I wondered if you got some that were older than mine. These $5 12SL7’s were in with the latest batch I got from RES - 1944 WW2 surplus.
And the SN7’s were a little weird - RCAs with some sort of shield inside? Maybe carbon to dissipate heat? They work - just never seen this before. I’ve gotten NOS RCA 12SN7’s before (from Stan) and they were just a regular clear bottle. |
#4340 |
for st-70, almost complete
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Let's see, what did we DIY today? | Magura | Parts | 7 | 5th June 2009 08:46 AM |
Today was the Day | EdT | Class D | 0 | 14th April 2007 01:23 AM |
today being April 1st | consort_ee_um | Everything Else | 1 | 1st April 2007 10:29 AM |
Is www.41hz.com down today ? | ashok | Everything Else | 2 | 25th August 2005 03:35 PM |
New To Site? | Need Help? |
