The Lounge A place to talk about almost anything but politics and religion.
And what did we buy today?
Thread Tools
Old 25th September 2020, 02:28 PM   #4321
cogitech is offline cogitech  Canada
cogitech's Avatar
Finally received all necessary parts to upgrade my PC. This is the first time I have made a (half-arsed) attempt at cable management. I decided to move all the hardware into a smaller, but more modern case that I had laying around (Cooler Master N200).
This is a pretty modest build by today's standards, but far, far more powerful than what I had been using for the past 8 years.
ASUS Prime B450M-A
AMD Ryzen 5 3600 (6-core, 12-thread)
Deep Cool Gammaxx 400 CPU cooler
16GB Corsair Vengeance LPX DDR4 3200Mhz
USB 2.0 Card Reader
I installed my existing SSD drives (3), HD, modular power supply and RX480 8GB video card.
After upgrading the UEFI BIOS to the latest version, I simply enabled XMP/DOCP to get the memory running at the right speed and enabled virtualization. Everything else left at defaults.
My existing Linux installation booted up instantly with zero issues.
CPU is idling at 32C and stays well below 68C during stress testing, which allows the max boost clock of 4.2Ghz to be maintained on all cores for extended periods.
I am now questioning whether I really need this much CPU power. I also have a new Ryzen 3 3100 and I am considering swapping it in to see if I am just as happy with it. I could sell the R5 3600 and put the money towards something else.
Old 25th September 2020, 03:43 PM   #4322
kodabmx is online now kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
Or keep the R5 because you'll want the speed eventually... Cheaper than upgrading later
My Ryzen is the first machine I have not bothered to overclock. PBS works so well that upgrading to an AIO 360mm water cooler would only net about 2% difference. The Wraith Prism cooler that AMD includes with it is quite impressive for stock, too.
Ask me about PCBs and kits for DIY tube projects.
Old 25th September 2020, 04:51 PM   #4323
cogitech's Avatar
"...Cheaper than upgrading later ..."
I don't see it that way at all. Now that I am up to socket AM4, my upgrade options are almost "unlimited" and prices are only going to go down. A couple years from now I will probably be able to get a used 3900x for peanuts.
On the other hand, I do really like this R5 3600 , and I already own it. Maybe I'll keep the R3 3100 and use it in a future upgrade of my daughter's PC.
Old 26th September 2020, 01:20 PM   #4324
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
A set of torx sockets so I could remove the air box on my wifes car!
Tony.
Any intelligence I may appear to have is purely artificial!
Photography (another hobby)
Last edited by wintermute; 26th September 2020 at 01:22 PM. Reason: Fix damage autocorrect! It even "fixed" this comment to autocorrelation
Old 26th September 2020, 01:24 PM   #4325
Pano is offline Pano  United States
Pano's Avatar
Torx sockets? What fresh madness is this??
Old 26th September 2020, 01:28 PM   #4326
just another
wintermute's Avatar
Yep I thought I had enough for any chore on a car, but nope. I've got a set of normal torx, Allens, SAE, Metric but no these are bolts that the heads look like a normal Torx driver!
No doubt the madness is designed to make the punter go "oh crap I don't have anything that could undo that, I better take it to the dealer".
Tony.
Last edited by wintermute; 26th September 2020 at 01:30 PM. Reason: add comment about madness.
Old 26th September 2020, 01:33 PM   #4327
kodabmx's Avatar
External Torx. Some bolts on my car use this, too. They work better for automated assembly.
Old 26th September 2020, 08:59 PM   #4328
kn0ppers is offline kn0ppers  Germany
A Brymen BM859s and some probemaster test leads to go with it.
Old 27th September 2020, 03:32 AM   #4329
rdf is offline rdf  Canada
rdf's Avatar
Berkeley Gorilla Stick GX2 plus a pile of soft baits.
Ears aren't microphones.
Old 27th September 2020, 05:43 AM   #4330
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
2 pcs ZN435
2 pcs ZN436
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
And what did we buy today?Hide this!Advertise here!
Thread Tools
Let's see, what did we DIY today? Magura Parts 7 5th June 2009 07:46 AM
Today was the Day EdT Class D 0 14th April 2007 12:23 AM
today being April 1st consort_ee_um Everything Else 1 1st April 2007 09:29 AM
Is www.41hz.com down today ? ashok Everything Else 2 25th August 2005 02:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
