The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Back panel kit (Schurter IEC with two fuse holders)
Old 20th May 2019, 07:39 PM   #1
MEPER is offline MEPER  Denmark
MEPER's Avatar
Default Back panel kit (Schurter IEC with two fuse holders)
I have purchased this kit and it is very nice but I have a question regarding the two fuse holders in the IEC connector. What is the reason to have to active fuses? .one is at the Neutral line and the other is on the Live line. They will be in series with each other. How can I avoid one of them?
Install a 10A in one holder and a 2A in the other (if 2A is the max. rating)?
Old 20th May 2019, 11:57 PM   #2
Tromperie is offline Tromperie  Australia
Are you sure one of the fuses is not a spare?
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 21st May 2019, 05:02 AM   #3
MEPER's Avatar
Yes, because it is the fuses which makes the connection from input pins (Neutral, Live) to the solder terminals on the inside.
Old 23rd May 2019, 02:18 PM   #4
Tuberoller is offline Tuberoller  United States
I also would like to know what 2 fuses are appropriate for an F5 build. Please provide a link to digikey or mouser if possible.
Old 24th May 2019, 12:25 AM   #5
WKCox is offline WKCox  United States
WKCox's Avatar
Here's what you're looking for:
021802.5HXP Littelfuse Inc. | Circuit Protection | DigiKey
Digi-Key Part Number F2427-ND
Manufacturer Littelfuse Inc.
Manufacturer Part Number 021802.5HXP
Description FUSE GLASS 2.5A 250VAC 5X20MM
Detailed Description 2.5A 250V AC DC Fuse Cartridge, Glass Holder 5mm x 20mm
Pass F5, M2x, ACA, B1, B1 Korg; Audio Research ST-70-C3; Dynaco ST-35; Audio Electronic Supply SE-1; Elekit TU-8500; Hagerman Bugle; Scan-Speak Solist MTM; Selah SA-1; Seas Loki; Cavalli eXStatA; Millett Hybrid MAX, Hybrid MiniMAX
Old 24th May 2019, 05:32 AM   #6
MEPER's Avatar
My question was why these IEC connectors in DiyAudio store kit need two fuses to work. The two fuses will be serial connected and the extra fuse does not add more protection as a single fuse would do. Two e.g. 3.15A fuses in serie does not add more protection than a single 3.15A fuse. It is a double contact version and it may add some kind of symmetry.
Old 24th May 2019, 12:19 PM   #7
WKCox's Avatar
This article may be helpful:
Double Fusing or Fusing Both Sides of the Line | In Compliance Magazine
"The only condition where fusing both phase and neutral conductors yields non-redundant protection against both faults is where polarity reversal is possible. That is, where the phase and neutral conductors could be interchanged on the supply side of the fuse. If polarity reversal is possible, then double-fusing guarantees that the phase conductor will always be provided with a fuse."
Old 24th May 2019, 04:22 PM   #8
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
If I am remembering this correctly, using two fuses is not allowed in Europe and should not be supplied here. It is not what feels like being safe, but applying the correct standards.
Regards Mark.
Old 24th May 2019, 05:59 PM   #9
MEPER's Avatar
Ok.....that is the explanation…..to ensure the phase always has a fuse. The Danish 230 VAC connects we insert in the wall outlet can be put in both ways so we normally don't have any control what is phase and what is neutral.
Thank you for that explanation!
Back panel kit (Schurter IEC with two fuse holders)Hide this!Advertise here!
Tightening panel mount fuse holders jackinnj Construction Tips 0 29th December 2018 11:48 PM
Nice Fuse Holders For Amp ElEsido Parts 1 20th December 2013 10:40 PM
Mounting fuse holders etc audiostrat Construction Tips 33 7th October 2013 09:13 AM
Source for Gold plated Bayonet Panel Fuse holders? jstang Parts 0 26th April 2009 07:23 PM
Source for Gold plated Bayonet Panel Fuse holders? jstang Solid State 0 26th April 2009 07:22 PM
Copyright ©1999-2019 diyAudio
