The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Starving Student II Headphone Amplifier
Old 25th March 2019, 04:42 PM   #21
pmillett is offline pmillett  United States
pmillett's Avatar
Originally Posted by DualTriode View Post
The install instructions call for R13 and R21 to be 1.4 watts.
Is this correct?
In the photos they look the same as all the 1/4 watt resistors.
Thanks DT
Sorry - fat fingers. '/' and '.' are right next to each other on the keyboard
Old 25th March 2019, 05:19 PM   #22
mpeg2 is online now mpeg2  United States
Originally Posted by pmillett View Post
That was pointed out to me by 6L6... on the next batch I made the pads bigger. Sorry about that!
Pete
Looks like I have to go back to the bench - a few oddities after a day of use: 1) Noticed that the turn on delay doesn't (hear a pop when first powered on - then about 10 min into listening, everything goes quiet for 10-15 sec). 2) Had one channel go completely silent (suspect an issue around one of the tubes).
I suspect some solder joint issues. Hard to actually see issues on inspection, so will trace out the circuit to find out where they are.
Most probably "operator" error.
Rich
Old 26th March 2019, 09:11 PM   #23
Spent some time tracing out the circuit - no problems found. Reflowed a few suspect solder joints & all the tube socket connections.
Appears to be working perfectly now.
A little more careful listening (SSII -> ACA -> Klipsch Cornwalls - playing Grissman/Garcia CD) - really nice combination, combines really well with the ACA and provides plenty of drive.
I would definitely recommend the SSII/ACA combination.
Rich
Old 26th March 2019, 09:37 PM   #24
pmillett's Avatar
Rich
Cool, glad it's working well for you.
Pete
Old 31st March 2019, 04:27 AM   #25
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
I managed to build one today. Some of the pads on the pcb are
quite small so it would have been easier if I had thinner solder on hand.
Also it took a bit of effort for me to put the tubes in.
I'm currently trying it as a preamp after listing to its headphone
output for a couple hours. I encountered one minor issue. I
toughed the volume know and I felt a bit of static and both channels
went silent. Perhaps the relay was somehow triggered. Anyway,
after turning off and on, it is behaving ok again.
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 31st March 2019, 01:14 PM   #26
Dennis: I'm sure you'll enjoy it.
I had some issues building mine - I was using a very (very) old soldering iron with a suspect tip - I think some of the solder joints on the small pads (especially the ones connected to ground) were not good. I picked up a new soldering station (moved to the modern world) & carefully reflowed all of the solder joints - everything is fine now.
Rich
Old 31st March 2019, 01:32 PM   #27
MEPER is offline MEPER  Denmark
MEPER's Avatar
The supplied Raytheon tubes are "made in Japan". Are those NOS? …..how old?
Old 31st March 2019, 02:16 PM   #28
MEPER's Avatar
I unpacked today and there was only one 47.5k resistor and no jumper sets. I checked several times. 47k I probably have in stock…...but jumpers are more tricky....
Old 31st March 2019, 02:41 PM   #29
aljordan is offline aljordan  United States
I built one a few days ago. I also had trouble with soldering using my 20+ year old inexpensive soldering station, which worked fine on the other gear I built. After soldering the resistors I finally figured I was building enough audio gear to buy a better soldering station. That helped a lot, but I still had to check everything carefully, as some of the pads and holes are so small.
Old 31st March 2019, 02:43 PM   #30
I think my jumper sets were in with the bag that included the relay.
Starving Student II Headphone AmplifierHide this!Advertise here!
Starving Student 12AU7 muskyhuntr Swap Meet 4 19th September 2016 09:48 AM
FS: P.Millett Starving Student hybrid headphone amp bikerbo Swap Meet 13 3rd January 2016 11:10 AM
Starving Student (20EZ7) jackinnj Headphone Systems 0 28th October 2015 02:57 PM
FS: Starving Student Hybrid Headphine Amplifier kuroguy Swap Meet 5 28th April 2010 02:43 AM
Starving college student needs a job! cowanrg Everything Else 11 28th June 2002 09:18 AM
Copyright ©1999-2019 diyAudio
