Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store. |
Thread Tools |
#191 |
Finally finished the exterior of my case with some Danish Oil on the oak front. The little black knob was the best of what I could find for a 6mm d shaft. I must make sure that I check the shaft size before ordering next time (no innuendo intended, honest).
A poor life this if, full of care We have no time to stand and stare. Last edited by SuppersReady; 3rd November 2020 at 10:39 AM. |
#192 |
Looks great! I built mine stock but into a custom case, as well.
![]() (Full size image: http://rkheck.frege.org/images/wood/SSII-03.jpg).
Pronouns: they, them, etc • System: DIY Turntable, Graham 2.2, Grado Statement Master, XP17 & XP20, Schiit Yggdrasil, Logitech Transporter, Aleph 1.2s, Dynaudio Contour 60s, Gotham Audio Cables • DIY Builds: Whammy, SS II, Balanced B1 Last edited by rikiheck; 3rd November 2020 at 04:50 PM. |
#193 |
Very nice!
I'm just starting with woodworking, that is something to aspire to.
A poor life this if, full of care We have no time to stand and stare. |
#194 |
Thanks! It's been a merging of two hobbies. I've made two Whammy's as well for friends.
Pronouns: they, them, etc • System: DIY Turntable, Graham 2.2, Grado Statement Master, XP17 & XP20, Schiit Yggdrasil, Logitech Transporter, Aleph 1.2s, Dynaudio Contour 60s, Gotham Audio Cables • DIY Builds: Whammy, SS II, Balanced B1 |
#195 |
Hey, I assembled everything according to the guide. When I do a smoke test I get around 42V on both pin3 and only the LEDs inside the tube sockets are lighting up. When I plug it it I hear a lot of cracking. I re soldered everything but I still get the above voltage. What can I do to find the issue?
#196 |
Just FYI, I initially had very bad microphonic issues with the Raytheon tubes supplied with the kit. Ringing when turning the volume control, or tapping the case, or even when the cord would sway when I was listening.''
I tried a different pair of Raytheons from EBay. No difference. Then tired a pair of RCA tubes. Problem gone. I don't (yet) have a view about other differences between these tubes. The RCAs are clearly better for me, so not much motivation...
#197 |
I've been using both iterations of my SSII with the Raytheon tubes for a while now. I hadn't got around to trying some of the other valves from the rolling kit that Peter Millett sent me last year.
![]() I've only tried the Tung-Sol so far. What a difference! I was only expecting minor differences in character, so initially I was only intending to listen casually whilst doing some domestic admin. Six hours later and a lot less domestic admin than planned... I only stopped because I suddenly realised what the time was and the battery on my AK70 was nearly empty. It is so much cleaner and exciting following the valve swap. Ridiculous amounts of low level detail from tracks I thought I knew well. Goosebumps and foot-tapping, 'nuff said! Thanks again to Peter Millett and the DiyAudio store!
#198 |
Hello,
I have a problem. When I do a smoke test I get around 43V on both pin3. I checked all my connections for shorts and cold soldering. I re soldered everything and removed the capacitors and checked if they are ok. Looking at the circuit plan I assume my mosfets are broken when the voltage is not right at pin3. I don't know how to check them, only guide I found says there has to be a high ohm resistor between the pins, which is the case. I assume some parts are broken, if it is not the mosfets how can I find the broken parts? Thank you. |
#199 |
I’ve been bothered by a slight ‘bathroom’ effect to the sound of mine - like listening in a tiled room rather than with soft surfaces, smearing detail, if that makes sense.
I initially thought it was my headphones (dt150), so did some work on those to good effect, but the big difference was changing the caps in the signal path. I’ve swapped out the wimas to better films, and c1 & 2 to np muses. What a difference! All the reverberant effect has gone, the imaging is much more ‘planted’, everything is so much more real (imho). If my experience is anything to go on, a change very well worth considering! Dave |
#200 | |
Unfortunately the diyaudiostore is sold out - anyone know of a source, preferably uk? Dave |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Starving Student 12AU7 | muskyhuntr | Swap Meet | 4 | 19th September 2016 09:48 AM |
FS: P.Millett Starving Student hybrid headphone amp | bikerbo | Swap Meet | 13 | 3rd January 2016 11:10 AM |
Starving Student (20EZ7) | jackinnj | Headphone Systems | 0 | 28th October 2015 02:57 PM |
FS: Starving Student Hybrid Headphine Amplifier | kuroguy | Swap Meet | 5 | 28th April 2010 02:43 AM |
Starving college student needs a job! | cowanrg | Everything Else | 11 | 28th June 2002 09:18 AM |
New To Site? | Need Help? |
