The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
5U deluxe direct from modu shop ... drilled wrong?
Thread Tools
Old 23rd April 2015, 06:41 PM   #1
kaan is offline kaan  Denmark
kaan's Avatar
5U deluxe direct from modu shop ... drilled wrong? Send a message via MSN to kaan
Default 5U deluxe direct from modu shop ... drilled wrong?
Hi all
Can someone confirm to me that the two 5U deluxe chassis i just received from modu shop is not drilled to DIYAudio specs?
Thanks in advance.
Old 23rd April 2015, 09:28 PM   #2
grimberg is offline grimberg  United States
grimberg's Avatar
Hopefully you have already figured it out, but in case you haven't, here is the clue you need.
Each side is made by two symmetrical halves. This means, each half of one side is the mirror image of the other.
Now that you have the clue, take a deep breath and rearrange the pieces. Once you do it, another question will pop in your mind and the answer is:
The holes should be on the top to make access to the PCB easier for measurements and adjustments.
Have fun!
Old 24th April 2015, 05:04 AM   #3
kaan's Avatar
You are of course right!
Thanks for the sanity check
  Reply to this post
5U deluxe direct from modu shop ... drilled wrong?Hide this!Advertise here!
Thread Tools
Deluxe chassis 4&5U directly from Modushop? coolnose The diyAudio Store 5 20th August 2013 03:18 PM
Modu Pessante Dissipante Assembly Nirvana5253 Construction Tips 1 22nd April 2013 02:40 PM
Modu chassis Ted205 Parts 7 6th May 2009 01:02 PM
Wilcox Gay 5U nhuwar Tubes / Valves 3 29th October 2008 02:16 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
