The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Amp Camp Amp Kit V1.6
Amp Camp Amp Kit V1.6 Please consider donating to help us continue to serve you.
Old 14th January 2020, 01:14 AM   #631
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Porter15 View Post
My high school son and I were congratulating each other on our pretty solder joints...then one of us soldered Q4 LK170 in “backward”—drain and gate reversed. After an ugly fix, I’m worried we fried the jfet.
Is there a way with a multimeter to see if the in situ, correctly oriented, but abused jfet Q4 is still alive? I would prefer to pause, get a replacement part, rather than finish the build to find one dead channel.
Please help as my kid is dying to hear Slipknot and The Offspring through a Pass circuit. On second thought...
Measure RDS. Its resistance between drain and source pins with power OFF. Circa 30 Ohm for a medium IDSS K170 is a healthy indication. Certainly not a short or an open indication or some kΩ for any IDSS. Compare with the K170 on the other channel.
No need to remove the part from the board in most cases for measuring that parameter.
Old 14th January 2020, 06:45 AM   #632
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
I did EXACTLY the same thing! Of course, not with a simple cap or replaceable part, with the unobtanium (then, now just pricey! ) part.
Luckily, it was perfect, no damage done even if the legs ended up crooked and the poor guy was heated severely during de-solerding.
I hope yours is as resilient as mine was!
Rafa.
Old 14th January 2020, 07:23 AM   #633
Porter15 is offline Porter15  United States
Salas and Rafa
Thank you for your helpful and encouraging replies. Salas, resistance measurement between drain and source in abused jfet approximately the same as jfet on other board: ~35 ohms. Thank you for your help—feel more confident we’ll have a working amp soon.
Old 14th January 2020, 11:09 AM   #634
ZACC is offline ZACC  Sweden
ZACC's Avatar
I'm doing a 4-way active build with Two (2 pcs) Firstwatt M2's. One on midbass (2 x 15") and one on midrange (2 x 8"). Sub (2 x 21") will be powered by a Crown XLS. As tweeter I will use Beyma TPL-150B.
Would a Amp Camp Amp be suitable for the TPL's? Total system sensitivity will be around 100dB so I guess the power of the ACA is enough.
The TPL also seems to be an easy load, see pic.
Artificial Intelligence usually beats natural stupidity.
Old 20th February 2020, 04:47 PM   #635
eyspot is offline eyspot  Germany
Help! Suddenly no sound out of one Channel. All voltage Checks are OK. Items is also warming up. Any idea?
Old 20th February 2020, 05:08 PM   #636
Alan4411 is offline Alan4411  Wales
Alan4411's Avatar
If you swap the left and right inputs round does the fault follow the input?
If you swap the left and right speakers round does the fault follow the speakers?
If no, then most likely to be a bad connection / solder joint. Look at the input and output connections.
Old 20th February 2020, 10:23 PM   #637
jfuquay is offline jfuquay  United States
How much experience do you have soldering? I wasn't flowing solder into the joints quite long enough on my first ACA and also had one channel go quiet after less than a week of use. Alan4411's suggestion sounds good, but really look at your solder joints and think about at least reheating them so solder really gets down into the joint.
Amp Camp Amp Kit V1.6Hide this!Advertise here!
Amp Camp #1 PCB Rudi_Ratlos Swap Meet 43 30th September 2018 12:12 PM
Amp Camp amp tttubes The diyAudio Store 3 15th November 2016 02:57 PM
Amp Camp Amp GregBaker The diyAudio Store 0 12th January 2015 12:41 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
