The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Amp Camp Amp Kit V1.6
Old 20th January 2019, 04:56 PM   #411
Sidsmith is offline Sidsmith
Originally Posted by Alan4411 View Post
Sorry, not from those results...
If it was a poor connection you would expect more than 10k not less.
But I am a little confused by the way you have shown the results too, I do not understand what 'and 0.5k' or '3.3K to R7 to pin D' means.
So as there are no numbers on the resistance picture on post #404, can you check them again and record the values please? Alan
All measure are form the gound.
I measure 3.2K between R5 and R7
I measure 500 Ohms between R7 the pin D of Q2.
I measure 3.3K between R5 and pin G of Q2.
Sorry my mistake.
Old 20th January 2019, 06:48 PM   #412
Alan4411 is offline Alan4411  Wales
Alan4411's Avatar
Sorry my mistake.
No mistake, just a different method I think.
And I am still not quite with you yet. So let's try something else.
Unsolder one end of R7, measure its resistance. (Should be 10k)
Next unsolder one end of R5, measure its resistance. (Should be 100r)
Leave them out of circuit for the next test.
Now put the Black meter lead on the ground wire.
Measure the resistance from ground to S, then from ground to G and again from ground to D of Q2.
Let us know the results. Alan
Old 20th January 2019, 10:10 PM   #413
drpro is offline drpro  United States
Perhaps Jason, future designs can use an East - West switch position instead of the North - South currently used.
I must build. Pass F4s, F6, M2, BA-3 preamp, MoFo, ImPasse preamp, Whammy headamp, Aksa's Lender preamp, Salas DCG3 headphone/preamp, XRK971 PCA & DCA headamp Bruno Putzey's balanced preamp, Doug Self preamp, Pete Millet Korg headamp.
Old 20th January 2019, 11:13 PM   #414
6L6 is offline 6L6  United States
6L6's Avatar
Why? There is a unwritten standard for audio equipment power switches, it's up, in, or clockwise to turn power on.
Old 21st January 2019, 12:35 AM   #415
Steve Luck is offline Steve Luck  New Zealand
In or clockwise is common for on but outside the US - down is common for on. Lots of countries outside the US have powersockets/outlets with switches on them that operaate down as on and the same with light switches.
Vive la difference!
Old 21st January 2019, 01:01 AM   #416
6L6's Avatar
Yes, I agree wholeheartedly and completely.
I did specify audio equipment, not light switches/mains outlets/etc...
Old 21st January 2019, 04:32 PM   #417
Mazeppa is offline Mazeppa  United States
+1
Old 22nd January 2019, 04:09 AM   #418
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
I have never seen a 'down - on' light switch: not in South America, not in Europe I think either.
I would switch off every light, every time I wanted to turn something on!
Old 22nd January 2019, 05:10 AM   #419
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
It has to be down for on otherwise how do you see the red dot on top that tells you it's switched on? Plus, my toaster is down for on!
Old 22nd January 2019, 07:37 AM   #420
UK power switch - Google Search
Amp Camp Amp Kit V1.6Hide this!Advertise here!
Amp Camp #1 PCB Rudi_Ratlos Swap Meet 43 30th September 2018 12:12 PM
Amp Camp amp tttubes The diyAudio Store 3 15th November 2016 02:57 PM
Amp Camp Amp GregBaker The diyAudio Store 0 12th January 2015 12:41 AM
Amp Camp! Jason Site Announcements 2 30th June 2012 03:57 PM
Copyright ©1999-2019 diyAudio
