The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 29th June 2020, 10:28 PM   #2001
carlmart is offline carlmart  Brazil
Originally Posted by jan.didden View Post
Please read my post. Do you understand what I am trying to say? Pencil in the voltages in the schematic. If you use a 6.9V ref, the bottom 1k resistor obviously has 6.9V across it. What is then the voltage across the top resistor?
The voltage across the top resistor has to be 30v minus 6.2v, 23.8v, which seems to get me a 3K9 value for the top resistor. That gets me 6.2v in +in and -in.
Old 30th June 2020, 07:10 AM   #2002
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Bingo! Almost. The ref diode is 6.9V, not 6.2V. So you get 23.1V across the top resistor.
How so?
Jan
Old 30th June 2020, 08:49 AM   #2003
laserscrape is online now laserscrape
Has a good lm329 alternative for 5V output been established?
Old 30th June 2020, 10:31 AM   #2004
In sot92 package The LT1009 has best noise performance after lm329 from what I found, but still over 2 times worse.. maybe im over obsessing on the noise figure?
It is a lot cheaper than lm329 which is nice.
Old 30th June 2020, 12:05 PM   #2005
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Super Regulator
Walt Jung invented the GLED431 for exactly this purpose: to create a shunt voltage reference circuit with the lowest possible noise. Although the diyAudio search is unable to find it (try the experiment if you don't believe me), Google succeeds
Mr. Jung's ultra-low noise VREF - the GLED431
Full and complete .pdf attached to post #56 of that thread
You will need to do some arithmetic to use it in a Super Regulator, since the low low LOW noise reference voltage it produces, is not equal to the reference voltage produced by an LM329. But DIYers are clever, crafty, and resourceful!
_
Old 30th June 2020, 01:13 PM   #2006
Thanks, very glad I asked.
Old 2nd July 2020, 07:36 PM   #2007
WaltJ is offline WaltJ  United States
WaltJ's Avatar
Default More on tweaking the GLED431 2.5v ref
_
While I do appreciate Mark Johnsonís comments on the GLED431 circuit and the very low noise it can achieve, I could not find the writeup with the thermal shield addendum. But for sure it can be found on my website:
https://refsnregs.waltjung.org/GLED4...014_092418.pdf
The lowest noise will be found when the circuit is fed with ample source current, i.e., 8mA or perhaps more. This is to ensure that the PNP is really running with at least 4mA of current.
Since the original setup with the 3mm thruhole GLED, I have built versions with a Liteon SMD equivalent diode. They worked virtually identical to the leaded LED versions. Agonizing to fit to a pcb, but great once soldered in place.
Also, a ZTX550 works well as the amplifier, and is slightly cheaper vs. the 951. Both are Diodes Inc. parts.
Old 2nd July 2020, 07:49 PM   #2008
diyAudio Donor
Super Regulator
Here's the .pdf attachment from post #56 ... and if you look closely, you'll see that post #56 was written by Walt himself!
https://www.diyaudio.com/forums/atta...4_092418_r-pdf
This .pdf is two and a half pages long; when I zoom way out to get the whole thing on my screen, it looks like Figure 1 below. When I view only the final page, I see something that looks like Figure 2 below. I *think* this is the thermal addendum but I could be mistaken.
_
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
