The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 17th May 2020, 05:54 PM   #1931
carlmart is offline carlmart  Brazil
Originally Posted by potstip View Post
ldo regulators have great noise and psrr performance. Only issue is high Zout compared with discrete regulators. after ldo is there any buffer circuit possible to decrease Zout?
Output impedance of LT3045 to 0,17mOhm @ 80Hz and 0,25mOhm @ 700Hz.
Simulation for LT3042, supposedly a bit inferior to LT3045, shows 12uOhm @ 80Hz and 29uOhm @ 700Hz.
Old 24th May 2020, 05:45 PM   #1932
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Super Regulator
That's because you have a heavy load on the regulator and pass transistor.
The convention is to use a 25mA load ... this keeps everyone on the same page when testing regulators for stability. (If I were to go back and retest all the regulators for the Linear Audio article I would use 25mA and run the Z-test out to a few megaHertz - )
Set I_1 to AC=1, DC=0.025 and eliminate R7, or AC=1, DC=unspecified, R7=600 Ohms.
D45H11 is in the LTSpice library isn't it? BD140 isn't a good choice as hfe is lower and safe operating area smaller.
Old 25th May 2020, 01:44 AM   #1933
Please make the changes you think necessary on the asc file and re-upload it.
Old 25th May 2020, 06:01 AM   #1934
meldano is offline meldano  Germany
Guys,
for LED D1,6 is there a special type necessary?
Can I choose a 2mA low current led. Is the forward voltage or the Resistor value for R2,9 important ?
Old 25th May 2020, 02:34 PM   #1935
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
It is possible, but I will leave it to more experienced members to explain any downsides and limits.
I built the Reliaxed2 pre-amp a decade ago. That design used an opamp at low gain as a buffer for an analog section power supply. Of course, an opamp is limited in current output capacity and most would struggle at the 25 mA test standard. And the opamp needed to be close to the load because of capacitance drive limits. But an opamp running near unity gain can have a low output impedance.
Naturally, this approach could be implemented with discrete components.
Old 27th May 2020, 09:40 AM   #1936
potstip is offline potstip  Turkey
In Reliaxed2 passive amp did you noticed any sound improvement of relay based volume control over standart cement or alps pots?
Old 27th May 2020, 12:33 PM   #1937
lehmanhill's Avatar
First, the Reliaxed2 isn't completely passive. It has a single opamp with about 6 dB gain in the signal path. That was used to control impedance.
I did compare it with a mid level Alps pot and also to a Lightspeed Attenuator that I borrowed from a friend. The differences weren't big, but I did prefer the Reliaxed2 over the Alps and Lightspeed.
Old 27th May 2020, 02:27 PM   #1938
amplidude is offline amplidude  Denmark
Default "Jung super regulator "
Hi all.
Surfed a bit around on fleebay and noticed this regulator, it uses lme49710 opamp, and I guess all those led's are current sources.
There's literally no specs on this thing which makes me suspicious.
Has anyone here tried one and maybe measured it? And the topology? I don't recognize any jung here.
Link to product.
HiFi Walt Jung Super Regulator DC Power Supply Board Linear Audio For DAC Preamp | eBay
Old 27th May 2020, 04:19 PM   #1939
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
This has nothing to do with Walt Jung or Linear Audio, typical trick to draw traffic.
You pays your dollar and you takes your chances, with no indication that it even does what they suggest.
Jan
Old 27th May 2020, 05:22 PM   #1940
Your problaly right, but it got me courius though
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
