The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 29th May 2019, 10:47 AM   #1661
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Abartels1965 View Post
Thanks Jan for answering this quick!
Is there any preferred opamp which is capable of +/-36V?
I tried to read all the 160+ pages, but it's a lot to read.
What kind of zener do you prefer for 60V regulated output?
Many thanks and cheers! (hmm, it's a bit early for a Bernardus Abt )
Alex
I'm not familair with high voltage opamps, but the OPA454 and ADA4700 come to mind. Not sure they fit the PCB footprint.
If you mean the zener on the opamp output, should be half total supply, but not critical. Only necessary to keep the opamp output away from ground and supply, so for 60V anything between 20 and 40V would work..
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 29th May 2019, 11:02 AM   #1662
Abartels1965 is offline Abartels1965  Netherlands
Abartels1965's Avatar
Thanks Jan, looking at datasheets of those opamps, they have rather high noise rates.
What are, in your opinion, the most important characteristics to look for in a suitable opamp in this design?
I haven't a clue what to look for, bandwidth, slew-rate, Noise, Unity gain, cmrr, etc?
Sorry for asking these questions, but I really haven't a clue
Pictures of my DA-M1 UltraCap powered Streamer: https://drive.google.com/drive/folde...-V1PFU2DU4brf7
Old 29th May 2019, 11:02 AM   #1663
EUVL is offline EUVL  Europe
ADHV4702-1 Datasheet and Product Info | Analog Devices
Patrick
xen-audio.com
Old 29th May 2019, 11:04 AM   #1664
Hi Patrick, I noticed that one too, specs seems great to me, but again, I haven't a clue if they are good for this design. If I am not mistaken, Jan did not like this one for regulator design
Old 29th May 2019, 11:57 AM   #1665
jan.didden's Avatar
Trust Patrick to find some exotics! ;-)
Spec-wise this looks good, the problem with this one is that it is hardly diy-solderable.
The ADA4700 is solderable, as is the OPA545. In this app the back plane soldering can be omitted, just put some thermal grease.
Slew rate is not that important, the output barely moves. Low noise is nice, wide bandwidth is nice. Ohh and unity-gain stable preferably...
Jan
Old 29th May 2019, 12:03 PM   #1666
Ok, thanks a lot Jan, and Patrick too
I soldered NDK NZ2520SD XO's by hand, they measure 2.5x2.0mm only, these ADHV4702 measure 7x7mm, they are big, hahaha
Maybe I will try them, or get some soldered to brown-dog adapter or other.
Cheers!
I will try LTC6090-5 first, 24m bandwith, 14n noise, little bit easier to solder
Old 29th May 2019, 12:20 PM   #1667
"The LTC6090 is unity gain stable. The LTC6090-5 is stable in noise gain configurations of 5 or greater"
Can I use the -5 version or not? If not I definitely will go for ADHV4702
Old 29th May 2019, 01:44 PM   #1668
jan.didden's Avatar
It's hard to say, there's a lot of gain in that loop, and for sure don't use the -5. You probably can compensate externally but without some pretty good scope and knowing what you do its hard. This is also for me uncharted terrain.
Personally I would give the 6090 a try.
Jan
Old 30th May 2019, 12:46 PM   #1669
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Super Regulator
On the BOM, the voltage divider resistors are specified as 1K, 0.25W metal film. Higher dissipation, better temco resistors are better (if you can fit them!).
Old 30th May 2019, 01:11 PM   #1670
jan.didden's Avatar
Especially with 60V, you need to recalculate the divider ratio of course, and there's much more voltage across the top R. P = E^2/R ;-)
Jan
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
Copyright ©1999-2019 diyAudio
