The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 8th March 2019, 02:19 PM   #1611
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Assuming D2 is in series with output of opamp, and the opamp output is at 1.18V, the regulator seemd to work OK, but there's an issue with the pass transistor or the input voltage. The opamp tries to pull base current to increase Vout, but can't go lower than 1.18V. Just an educated guess.
And again, measurements at the opamp pins and the pass transistor pins are much more telling.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 8th March 2019, 03:56 PM   #1612
powermike145 is offline powermike145  United States
Mr. Didden, thanks for the quick responses! Iíll take those measurements and report back.
Old 8th March 2019, 07:27 PM   #1613
D2 Zener diode is in series and has the correct orientation. Picture of the board is attached below. I took the following measurements with a 34.2V board input. All measurements are referenced to POS return:
U1 - IN: 7.86V
U1 + IN: 7.25V
U1 out: 1.11V
Q1 E: 12.5V
Q1 B: 13.1V
Q1 C: 34.1V
Q2 C: 13.1V
Q2 E: 32.0V
Q2 B: 31.4V
I also took a few more measurements with different input voltages. The super reg output stayed constant at 12.5V. Unfortunately, I took the wrong reading for the non inverted opamp input-so I don't have it-but here is the rest.
32.7V input:
U1 - IN: 7.86V
U1 + IN: ??? (I can go back into work and measure if needed)
U1 out: 1.1V
Q1 E: 12.5V
Q1 B: 13.4V
Q1 C: 32.6V
Q2 C: 13.1V
Q2 E: 30.1V
Q2 B: 30.0V
28.0V input:
U1 - IN: 7.86V
U1 out: 1.1V
Q1 E: 12.5V
Q1 B: 13.1V
Q1 C: 28.2V
Q2 C: 13.0V
Q2 E: 26.3V
Q2 B: 25.7V
25.4V input:
U1 - IN: 7.86V
U1 out: 1.1V
Q1 E: 12.5V
Q1 B: 13.1V
Q1 C: 25.4V
Q2 C: 13.0V
Q2 E: 23.6V
Q2 B: 23.0V
From your last post, I guess having over 600mV difference in opamp input is not good. Since I increased R5 from 4.99k to 8.25k(to keep D5's forward current=2mA) and R6/7 from 1k each, to 2k and 4.99k respectively; maybe these increased resistances are the issue? If so, I could lower the R6/7 divider to something like 1k and 2.5k, but not sure what to do about R5. Do you think changing the resistors is the right place to start? Thanks again for all the help!
Old 8th March 2019, 07:42 PM   #1614
jan.didden's Avatar
U1 - IN: 7.86V
U1 + IN: 7.25V
U1 out: 1.11V
So the output voltage divided down by the two resistors comes out to 7.86. Because that's higher than 7.25, the output of the opamp is slammed to ground.
You have an issue with those two resistors that divide down the Vout to -inp. The ratio should be (24-6.9) on top and 6.9 at the bottom. Check that.
Jan
Old 8th March 2019, 11:41 PM   #1615
Of course! I had R6/7 reversed. I had the right values to give 24V (2K and 4.99K), just stuffed on the board wrong. I swapped them and now have 24.5V steady output.
Mr. Didden, thanks again for all the help! If I every make it back to Belgium, I owe you a beer or two. Maybe an Orval or Rochefort 10? My favorites.
Old 9th March 2019, 06:54 AM   #1616
jan.didden's Avatar
Beer is good ;-)
But seriously, these regulators are a simple circuit. You only need to know ohm's law and opamps. 99.9% of the issues can be diagnosed easily from looking at the opamp inputs and output.
If the -inp is higher than the +inp and Vo is too low, there's a problem with the feedback divider. It is that feedback divider that sets Vo, everything else is secondary. The only thing the opamp does is move its output to try to make -inp and +inp equal; it has no idea what a 'regulator' is. So if the opamp output is slammed to gnd or Vo, it is trying but not getting there.
Jan
Old 25th March 2019, 07:48 PM   #1617
ApolloZhang is offline ApolloZhang  Europe
Managed to finish the last 60 Pages or so, must admit that, Jan, you really have my respect, for repeating the same contents over the years, again and again...
Back to the topic.
Just read Erno Borbelys latest All Fet Super Reg, it seems that Mr. Borbely basically made an error amp out of Jfets, the rest is pretty the same as other Shunt regs.
It occured to me that, why not just build a single stage error amp? So heres some crude simulation in LTSpice:
Regulator.asc
PSRR in HF seems okay, but strange phase shift?
Point in using a single stage error amp is to minimize noise in this part, since one can use bjts with low Rbe to achieve even lower noise than ops like ad797, IMO....
Old 25th March 2019, 08:15 PM   #1618
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Super Regulator
Output impedance is inversely proportional to error amplifier gain. To get SuperRegulator class output impedance you need LOTS of error amplifier gain. Among your design choices are (a) use an error amplifier topology with two gain stages; (b) duplicate the 140 dB gain that Scott Wurcer got from a single gain stage {folded cascode} using monolithic matching tricks; (c) positive feedback.
Old 25th March 2019, 08:42 PM   #1619
Oops, getting 140dB of gain with discrete elements sounds pretty impossible, not to mention that most Op-Amps have OLG lower than 130dB...So the ad797 stays the best error amp for a SuperReg?
Old 25th March 2019, 08:55 PM   #1620
jan.didden's Avatar
AD797 is very good but you need to be very diligent in wiring and general layout to avoid instability in this application.
I've had best results with the AD825 in pretty much any situation, clean, stable and dependable.
Jan
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
Copyright ©1999-2019 diyAudio
