The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Power Supply Soft Start Board (V3)
Old 14th March 2020, 03:52 PM   #351
turion64 is offline turion64  United States
Ah, so you’re looking to experiment with C1 & C5 ?
Pete
Old 14th March 2020, 06:09 PM   #352
thomasnadeau is offline thomasnadeau
Pete
Yes exactly. I've got both the Solen silver and regular audio caps, plus the Jensens and was going to give the Mundorfs a shot too while I am at it. I built a stock one which is my base line, and am building a second one to experiment with various caps and opamps now.
--Tom
Old 20th March 2020, 01:48 AM   #353
Originally Posted by Jason View Post
This thread is for discussions about the Power Supply Soft Start Board (V3) in the store. This is an updated version of the Soft Start V2 boards, primarily to make them compatible with the 10x10 grid mounting pattern we've now standardized on so they can be easily mounted to Deluxe chassis baseplate, riser panels, front panels and/or heatsinks. Refer to the Soft Start V2 discussion thread for additional information.
Change History
  • 2.0 First Production Version
  • 2.0.1 Added board dimensions
  • 3.0 New Layout
    • Double sided board
    • Moved AC in and Txfrmr connections to ends of board
    • Added Keystone connectors as option
    • Conforms to 10mm mounting grid
  • For future changes
    • Add polarity markers for electrolytic capacitor
Information
  • Product Page
  • BOM - Attached below (Last updated: Jan 14 2014)
  • Schematic - Coming soon
  • Dimensions - 110mm x 55mm
A note to anyone ordering that the following part numbers are incorrect on the .pdf BOM referenced above:
1 LED1 Red 5mm Red diffused LED 78-THLR6400 2.54mm
1 LED2 Green 5mm Green diffused LED 78-THLG6405 2.54mm
should be these Mouser part numbers:
1 LED1 Red 5mm Red diffused LED 78-TLHR6400 2.54mm
1 LED2 Green 5mm Green diffused LED 78-TLHG6405 2.54mm
Also note that the Omron relays are now these two models as the ones shown in the BOM .pdf are listed as obsolete (note the voltages):
653-G5Q-14-DC12
or
653-G5LE-1-ASIDC5
Happy Trails!
Power Supply Soft Start Board (V3)Hide this!Advertise here!
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 1227 Today 02:46 AM
Power Supply Soft Start Board (V2) Ana The diyAudio Store 195 1st March 2020 10:57 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 396 1st March 2020 10:29 PM
soft start power supply for dynaco st-70 yero Tubes / Valves 9 8th July 2011 08:43 PM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 04:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
