The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Power Supply Soft Start Board (V3)
Old 7th November 2018, 06:51 PM   #291
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
One reason might be that an influential textbook (Audio Power Amplifier Design, 6th edition, by Douglas Self) recommends this approach and NOT the Negative-Temperature-Coefficient-Thermistor inrush current limiter approach.
Another reason might be that an influential website (Elliott Sound Products) recommends this approach and NOT the NTC-Thermistor inrush current limiter approach.
A third reason might be all of the previous messages in this thread, which report success with this board. Dozens and dozens of people have used this board successfully in their audio equipment. On the other hand you only have the assurance of one person (your EE colleague) that the NTC-Thermistor Inrush Current Limiter will be successful.
A fourth reason might be power loss. The NTC-Thermistor Inrush Limiter will gobble up about 1% of the incoming mains voltage, leaving "only" 99% of the mains voltage applied to your audio gear. This PCB applies the full 100% of the mains voltage to your gear.
A fifth reason might be flickering mains. The NTC-Thermistor Inrush Current Limiter needs 60 to 180 seconds to reset itself. After you turn off your equipment, you should not turn it back on for 60 to 180 seconds, which gives the NTC-Thermistor ICL enough time to cool down and become ready for a new inrush. However if your AC mains experiences flickering or On-Off-On-Off failure in a brief period of time, or if your wife or child flicks the power switch on and off too quickly, then you will not get any inrush current protection. This PCB resets immediately and does not require any cooling time between on/off events.
A sixth reason might be heat within the equipment chassis. The NTC-Thermistor ICL will remain warm to hot to Very Hot while the equipment is turned on. This might be frightening, or possibly dangerous to other components and cables inside the chassis, or possibly dangerous to repair personnel. This PCB does not remain warm or hot while the equipment is turned on.
It may be worthwhile to mention that many of the amplifier PCBs sold in the diyAudio store (F4, F5, F6, M2X, ACA, AlephJ, etc), are circuits that were designed by Nelson Pass of Pass Labs and First Watt. Mr. Pass recommends a power supply circuit for these amplifiers, which includes NTC-Thermistor inrush current limiting and not this PCBoard.
Old 11th November 2018, 04:57 PM   #292
patoperro is offline patoperro
Thank you for your very thorough answer Mark. I would also have to adapt the circuit for 220v, so I'll need to look into that next.
Old 12th November 2018, 07:13 AM   #293
astromo is offline astromo  Australia
Thanks Mark, that's an excellent run down of the pro's/con's and considerations. Not having thought it through too hard, I've sourced componentry to go either or both ways. Your commentary gives me an excellent spring board to think matters through.
Old 2nd December 2018, 06:45 PM   #294
jphabc54 is offline jphabc54  United States
I recently integrated the soft start board into my F5 build. Multiple power ups went as expected and everything looked good until I started biasing the F5 channels. With one channel at full bias and the second channel at about 70 percent bias, the 180R / 5W resistors went nuclear — solder joints glowing and smoke coming off of them. Any thoughts on what might have gone wrong?
Old 2nd December 2018, 08:34 PM   #295
NM — I had C3 installed backwards. Square pad is positive! Now I hear the switch engage. I can’t believe it still works.
Old 12th February 2019, 01:01 PM   #296
kevinr is offline kevinr  United States
Default Transformer
Does Mouser carry a transformer that is a good choice for this pcb in a stand-alone case ?
I printed out the BOM but didn't see a p/n listed for one
In reading through the threads for v2 and v3 posters are using various transformers in various configurations, so it is not clear
Thank you
Old 12th February 2019, 01:33 PM   #297
Thank you
I don't know where I found it (it's not included at Post #1) and it's not linked on the relevant store page but check out the write up here:
diyaudio-softstart-build-guide-v1.0.pdf
Particularly, the detail provided on p. 13.
[EDIT: Although, you'd need to make some adjustments to account for the v3.0 PCB changes as offered at Post #40:
I may be wrong and am happy to be educated but transformer selection doesn't feature in a big way. There is commentary on p.5 regarding transformer VA rating. Apparently, the PCB "works well even with high VA transformers".
What "high" means I can only guess but I'm working with a 400VA toroid to power an Aleph-J. That's more than the minimum but I'm not going crazy, so I'd expect I'll be right with a plain vanilla BoM. What appears to be important is to align your supply's AC mains voltage with resistor specification R15-R18 and the capacitance of C9.
EDIT:
Note that with the v3 board, the Reference Designators are different. By my interpretation, I get the following equivalence:
C9 (v1.0) = C2 (v3.0)
R15-R18 (v1.0) = R3-R6 (v3.0)
I'd appreciate a check on all the info that I've related. This board is fed directly from the mains, so it's a smart move to be sure of the detail.
Also, if you look at the comments from Post #17 on, there are some pretty sizable VA ratings mentioned:
Old 12th February 2019, 02:36 PM   #298
Build guide link above got borked and my post timed out:
https://www.diyaudio.com/media/build...guide-v1.0.pdf
Dunno how. Hopefully this works.
Old 14th February 2019, 04:59 PM   #299
Default power supply for soft start
Thanks for your post astromo .
I did read through those posts and links; but hobby wise at this stage I'm pretty much just a "parts changer" as they say.
I was hoping to get referred by someone here on the forum to a part number from Mouser for a transformer to power the soft start pcb.
I just don't see anyone selling a speaker protector circuit ready to go anywhere online.
That online auction site has some assembled speaker protection circuits from Asia showing 12 Volts needed for power but I wanted to go with something here in the US first from the diyaudio store if possible.
Is a SMPS an option to power the Soft Start board ?
Old 14th February 2019, 06:08 PM   #300
mrdave45 is offline mrdave45  United Kingdom
If its the same pcb Ive got, the soft start is powered by the mains, then the soft start part of the circuit goes in line with the primary of the main tx. Have a look at schematic and see what it's hooked up to. Can you see anywhere to connect to a second transformer?
F4, Impasse, His masters noise, Troels Gravesen OBL15 and a stack load of analogue synths.
Power Supply Soft Start Board (V3)Hide this!Advertise here!
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 790 Yesterday 10:15 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 388 12th February 2019 10:33 AM
Power Supply Soft Start Board (V2) Ana The diyAudio Store 194 18th September 2014 09:42 AM
soft start power supply for dynaco st-70 yero Tubes / Valves 9 8th July 2011 09:43 PM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 05:26 PM
Copyright ©1999-2019 diyAudio
