The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V3)
Old 15th November 2019, 06:54 PM   #371
escucalin is offline escucalin
escucalin's Avatar
Originally Posted by turion64 View Post
Hi folks...I just finished building the speaker protect circuit using the 12VDC relays. The center tapped transformer I bought to power the circuit ( supposed to have been 12-0-12, TRIAD F-45X) measures 29VAC across the two outside secondaries. I tried it out anyway. The circuitís LED did what they were supposed to do (wow what a rapid blinking) and the speaker input-outputs has continuity after the relays clicked on. My question is if the 29VAC will be too much for this circuit/relays over time and should I seek a slightly lower output transformer, say 24-26VAC?
Thanks! Pete
Hello Pete,
A 29V AC would go to 40V after rectification and a bit of filtering.
Maybe using a LM317 to bring down the utility rail to 24V would spare you the expense of another trafo.
Old 15th November 2019, 07:07 PM   #372
turion64 is offline turion64  United States
Thanks, I will explore that..I measured 29VAC in (whether under the circuit load or not) and 17VDC across pins 2&5 of each of the relays. The stats sheet says the relay can handle 170% of max rated voltage so Iím assuming that means each relay can actually handle up to 20.4 VDC?
Originally Posted by escucalin View Post
Hello Pete,
Old 15th November 2019, 08:16 PM   #373
escucalin's Avatar
Their consumption is very low,
Would be better to power them with 11V not 17V for a reliable coil life
A regulator can fit on a wire if nicely shrink wrapped and even include a 200mA resetable fuse.
But hey if it works ... you have my 2 cents
Old 16th November 2019, 03:19 PM   #374
Iím grateful for your input, really. Some questions though: so would this be an appropriate resettable fuse (mouser; 530-0ZRR0010FF1E)? For setting 24V out of the LM317 I could use 180R for R1 (between ADJ and Vout pins) and 3.3K for R2 (from ADJ to neutral/return wire of AC line)? Heat sink needed? Where would the resettable fuse be connected?
Thanks, Pete
Old 16th November 2019, 06:45 PM   #375
escucalin's Avatar
Thanks, Pete
The fuse protects the circuit from accidents si it can go a bit higher .. 500mA
It goes right after the transformer output .
The voltage regulator resistor values are good See here : LM317 Resistor and Voltage Calculator
It does not need sinking under 200mA or so the circuit draws.
So go nuts on the shrink tube and enjoy!
Speaker Turn On Delay and DC Protector Board Set (V3)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V2) Ana The diyAudio Store 185 16th February 2018 03:08 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 07:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 08:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 10:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 06:57 PM
Copyright ©1999-2019 diyAudio
