The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V3)
Old 30th November 2018, 09:03 PM   #341
Hicoco is offline Hicoco  France
Just a quick note
i have a double full bridge rectifier for the power supply of my Amp after the 25-0-25 volt transformer, so i am connected on 0-25v before one of the bridges for the DC protection board
Old 28th December 2018, 05:42 PM   #342
avinunca is offline avinunca  Europe
Have just assembled and carefully checked my DC protection board I was surprised to find C6 was overheating. I had installed it with the neg side inserted into the square pad side.
Turns out this side is positive! After removing the cap I measured the voltage on the pads. I checked my board against the image posted just above (Astromo). Has anyone else discovered this?
Old 28th December 2018, 06:53 PM   #343
Having sorted that out with the relays operating normally, I find the pcb
is laid out to use the relay's bottom right contact - must be NC (viewing bottom of relay with coil connections on the lhs). My relay, Omron G5LE-1A4 has no contact in that position having just three in total.
Old 28th December 2018, 07:01 PM   #344
jhofland is offline jhofland  United States
Rod Elliott's writeup describing his P33 project offers some good information regarding the use of relays for speaker protection. One point, in particular, is using the NC relay contact to short the speaker to common (ground) when a fault occurs.
Old 28th December 2018, 07:31 PM   #345
Thanks for that. Problem is I am 99% done. Just having a problem finding a relay which has the NO contact on bottom rhs (with relay bottom up).
It is this position which tracks through to the SPK1 and SPK2 terminals.
Update - I realise my error. I imagined it would be easier to troubleshoot if I populated the board on the opposite side to the component labelling so I could still read all of it. I figured it wouldn't matter but I see now that the relays are the only components that must be soldered to the same side as the labelling. You live and learn!
Old 16th January 2019, 12:42 AM   #346
batty is offline batty  Australia
I am putting mine into an M2X, where can I tap off 24v AC from the PSU? or am I better using a separate transformer. Would 20VA be enough?
Townshend Rock II, My new TT since 1986.
Old 16th January 2019, 10:11 AM   #347
This question has been asked previously.
I found this response. Quote - a trafo of 10-15VA was recommended
There's only one place to tap ac voltage from the psu - off the transformer before rectification. However, I have 18vac transformers on my psu (dual mono)
For my speaker protection board I used Mouser part 553-VPL24-400. It's a 10VA 12/24vac transformer.
Old 16th January 2019, 10:53 PM   #348
Old 23rd January 2019, 08:47 PM   #349
Small transformer purchased.
Speaker Turn On Delay and DC Protector Board Set (V3)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V2) Ana The diyAudio Store 185 16th February 2018 03:08 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 07:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 08:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 10:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 06:57 PM
Copyright ©1999-2019 diyAudio
