The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V3)
Old 30th August 2018, 01:17 PM   #321
Roadrune is offline Roadrune
Hi, new member and first post, so be kind
I just built two of theese boards, one working fine, the other one however is only opening one relay.
I powered them from a 15VDC powersupply i had from before, using 12V relays that might be low, but the three other relays are working fine.
Now my skills in electronics are REALLY low all i could find out was that this relay got now power to the coil, and the Ohm was different over the last rectifier then all the other ones, so i swapped it for a new one.
Now i get power to the coil, but it still wont close...
I messed up my order for parts so i have double of everything except the relays, so my question is: can it be anything else than a faulty relay?
Sorry for my bad english (im Norwegian) and for the poor explanation (i am a plumber)
Old 14th October 2018, 08:50 AM   #322
astromo is offline astromo  Australia
Howdy, question about source voltage (and I don't think this has been specifically asked from my travels through the thread. Apologies if I missed relevant comment) and here goes:
Based on the commentary here from Post #50:
Does that mean if I'm planning to use a main PSU transformer with 18 VAC secondaries, then for K1 and K2 it would be appropriate and workable to select an Omron G5LE-1A4-DC9 as alternate components:
G5LE-1A4-DC9 Omron Electronics | Mouser Australia
and that way I could simply take a feed off one of the 18 VAC secondaries to power the board?
Thanks in advance.
Old 15th October 2018, 06:58 PM   #323
Originally Posted by mattmcl View Post
Thanks! Do you happen to have a replacement for 78THLR6400 and 78THLR6405 (LEDs)?
Originally Posted by dbis View Post
I think I ordered 78-TLHR6400 and 78-TLHG6405 from Mouser for those but maybe I got the BOM numbers wrong. They are both still in stock though. Anyway I'm not sure how much it matters if you get the ones on the BOM. I haven't powered my board up yet.
This looks like a straight up typo in the BoM to me.
The "TLH" in the part number quoted by dbis appears to refer to a Vishay make component. I understand that the component is generic but it wouldn't hurt to update the BoM so that a directly locatable part is called up.
And, just for fun, the listed 400V rectifiers (i.e. D3, D4, D5, D6) are coming up as obsolete for me and Mouser is redirecting me to this alternative:
Find Electronic Components | Mouser Australia
Any foreseeable issues with that?
Old 16th October 2018, 05:19 PM   #324
nater01 is offline nater01  United States
I am looking at using this board in an amp that does a touch over 800 watts into 4 ohms... Does anyone have any recommendations on which relay I could use? I will run a separate 12v transformer
Old 9th November 2018, 05:12 PM   #325
CubeDweller is offline CubeDweller  United States
The RLG suffix breaks down to RL="Tape&Reel" and the G="Pb Free"
It's the same diode as in the BOM otherwise.
Secret Decoder Ring here: http://www.onsemi.com/pub/Collateral/1N4001-D.PDF
Jeff
Old 14th November 2018, 08:36 PM   #326
Hicoco is offline Hicoco  France
Hi, do you have DC Protector Board left ? thanks
Old 20th November 2018, 09:30 AM   #327
Looks like this thread is dead now...i need dc protection i believe that i will etch my own PCB...
Old 20th November 2018, 09:35 AM   #328
Looks like this threat is dead now...i need dc protection i believe that i will etch my own PCB...
Sure, go for it.
Or, do what I did and check the diyaudio store and pick up the board in all its lovely, gorgeous blueness.
Old 20th November 2018, 09:52 AM   #329
Sure, go for it.
Thank, but i need just a DC protection.....
Old 20th November 2018, 01:02 PM   #330
Understood.
I'm sure this point has been raised previously. Check the thread's earlier posts
If I recall correctly, the deal is that you get both boards even if you only want one or the other.
I'm intending to use both, so this point didn't worry me.
Speaker Turn On Delay and DC Protector Board Set (V3)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V2) Ana The diyAudio Store 185 16th February 2018 03:08 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 07:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 08:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 10:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 06:57 PM
Copyright ©1999-2019 diyAudio
