The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
V3 Universal Power Supply Circuit Board
Thread Tools
Old 22nd September 2020, 01:01 AM   #421
Wessideg is offline Wessideg
Location: St. Paul, MN, (previously Detroit, MI Marquette, MI, etc.)
Thanks, I appreciate it.
Old 22nd September 2020, 01:14 AM   #422
6L6 is offline 6L6  United States
6L6's Avatar
The circuit with 7812 is incredibly simple, just a small cap (value not very critical) on each side of the regulator. If you get one in TO-220FP (the plastic insulated version) you can just attach to the chassis floor for heatsinking. The caps and wires can be attached directly to the pins.
File Type: jpeg 225BD265-5969-4E9C-B260-DF27598FE386.jpeg (31.6 KB, 223 views)
Old 16th October 2020, 01:56 PM   #423
myleftear is offline myleftear  Switzerland
myleftear's Avatar
Default Adjustments for F4?
Hello
Uhm, so for the F4 which becomes true, what adjustments should I make concerning the bleeder resistor (R9, R10), and since I‘ll try making the rectifier part too, is the output snubber required? (Not sure anymore about this, whether it is not required because of the constant current draw of a class-A amp?
I‘ll try not to ask too many too basic question (except these 2 for a starters)
Thank you
All the best
d.
dobedobedo...
Old 16th October 2020, 03:01 PM   #424
myleftear's Avatar
Hello
Thank you
All the best
d.
dobedobedo...
Old 16th October 2020, 03:34 PM   #425
6L6's Avatar
Bleeder resistor is there to discharge the capacitor bank after power-off. It’s value is not critical at all. 2.2k is a common value and works perfectly. Anything from 1.5k to 10k is again, completely fine.
Leave the output snubber open. The next PSU will not have one, it’s worthless.
Old 16th October 2020, 04:18 PM   #426
myleftear's Avatar
Thank you, 6L6!
(And you were quite right on the F4/PSU: pretty nice to put together, once the scare is shaken off V3 Universal Power Supply Circuit Board)
dobedobedo...
Old 1st November 2020, 02:03 PM   #427
AddiDub is offline AddiDub  Germany
I have build a Universal Power Supply circuit board. It seems to work fine and i tested it with my M2x boards, drawing 2,6A per PSU rail. My toroid ist a bit oversized with 500VA.
My negative voltage rail seems to have unmeasurable AC voltage at the output, while my positive rail measures around 50 mV ripple voltage. Measurements are the same with load applied or without load.
I triple checked all solder connections. Does anyone have an Idea how to find the culprit?
Old 2nd November 2020, 07:48 PM   #428
I will answer my own question. First i realised that i used a wrong range setting for measuring the AC ripple voltage at the output. When i use the "mV" setting my DVM reads around 7mV ripple (not 50mV) between V+ and ground.
My DVM only measures AC voltage when i connect the red clamp to the point with higher DC potential and the black probe to the point with lower DC potential. To measure the positive rail i had to connect the red clamp to V+ and the black clamp to ground. To measure AC ripple voltage on the negative rail i had to connect the red probe to ground and the black probe to V-.
Using this method and the mV range on my DMM both positive and negative rail measures AC ripple voltage around 7mV.
I will repeat measurements next weekends using my CRO. I was too lazy to set it up in my living room workshop that must be cleaned after every DIY session.
Old 24th November 2020, 01:33 AM   #429
DaveFred is online now DaveFred  Canada
Question about PI resistors,
Are they recommended for Class AB or just Class A amplifiers?
Thank you,
David.
Old 24th November 2020, 06:42 PM   #430
Ben Mah is online now Ben Mah  Canada
Class AB amps draw varying amount of current so a CRC filter would vary the voltage available, depending on the value of the resistor. The current could vary from tens of milliAmperes to many Amperes, so the power supply voltage variation due to the voltage drop across the resistor could be quite large.
Class A amps on the other hand have only small current variation so the power supply voltage variation is quite small.
Although a C filter has much higher ripple than a CRC filter, Class AB amps are push-pull and they have high Power Supply Rejection Ratio (PSRR), so higher ripple can be tolerated compared to a single ended amp which has low PSRR.
V3 Universal Power Supply Circuit BoardHide this!Advertise here!
Thread Tools
ACA with Universal Power Supply bnorrish Pass Labs 11 15th December 2019 10:51 PM
Universal Power Supply PCB Peter Daniel Audio Sector 78 13th December 2019 02:13 PM
Universal power supply board for audio amplifier siliconray Siliconray Online Electronics Store 11 13th February 2012 06:24 AM
■■■■Free Universal Power Supply Board For Tube Amplifiers ■■■■ siliconray Siliconray Online Electronics Store 2 10th January 2012 10:05 AM
My (almost universal) power supply Yoshy Power Supplies 0 7th September 2008 01:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
