The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
diyAudio F5 Build Guide
Old 2nd May 2018, 05:51 PM   #31
6L6 is offline 6L6  United States
6L6's Avatar
Well... I am working on the new guide.
Here's an "in-progress" sneak peak. Might help you out.
Amplifier schematic. Print out and have in front of you at all times.
Right - PCB bag. Left - Kit of F5 parts.
The current F5 PCB from the diyAudio store. It has the inclusion of potentiometer P3, and is the third revision of this board, hence "F5v3"
The parts kit includes everting for the PCB except the input Jfets and the LED
One channel's parts
The Dale resistors have thier value printed on the side, the code is 3-digit + multiplier at values greater than 100ohm, and below 100ohm the "R" is the decimal.
So, from top to bottom you see
10K (100+2 zeros, 10000ohm)
1K (100+1 zero, 1000ohm)
100 ohm (100+0 zeros, 100ohm)
10.0 ohm (10R0, 10.0 ohm)
Lead spacing for all small resistors is .5inch (12.7mm)
Measure all resistors before inserting into the board!
Left side
Center
Right side
Big resistors installed. Blue are 0.47ohm 3W, Orange are 100ohm 3W. Values printed clearly on the side of each resistor.
Note that the parts kit does not include the LED or it's resistor, this is so you can choose that you prefer.
I used blue and a 15K resistor
Install the 5K pot and the ZTX450 on this side (Q6). Note the orientation of the transistor. The potentiometer value is almost the same code as the resistors - 502 is 50+2 zeros , 5000 ohms
Q5 is the ZTX550, note orientation, and use another 5K pot here.
The 200ohm pot mounts in the center, and the Jfets install as shown. The K170 is the N-channel, the J74 is the P-channel.
Mount the thermistors as shown and don't bend then yet.
Stuffed PCBs
Old 2nd May 2018, 05:52 PM   #32
6L6's Avatar
Old 2nd May 2018, 06:00 PM   #33
ericacaylar is offline ericacaylar  United States
Thanks!
Old 6th July 2018, 07:42 PM   #34
tombalabomba is offline tombalabomba  France
Thank for your clear and well illustrated build guide. I just finished building the amp boards, I used a build guide from 2012. In this build I noticed that the pots were mounted the other way around as well as the jFets. Am I missing something? If so I will have to desolder every thing. Thank for your reply.
Old 27th August 2018, 10:18 PM   #35
Mrshazbot is offline Mrshazbot  United States
The attached photo has this blue what looks like a thermistor. The BOM and the schematic only lists the CL60 but this one appears to be different. Can you tell me what this is so I can order one?
Old 27th August 2018, 11:13 PM   #36
Panoff is offline Panoff
Default v 1.6 Build Guide - where and when?
Just looking for the build guide for V 1.6. It was supposed to be available sometime this month, but can't seem to find it--- anyone have more information?
Old 27th August 2018, 11:15 PM   #37
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
That should be a x-rated suppression capacitor. Perhaps one of these:
ERP610W332MEJ0 KEMET | Mouser Canada
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 27th August 2018, 11:18 PM   #38
6L6's Avatar
Mrshazbot - Dennis is correct, that's a 3300pF line-rated capacitor.
His link to the part is a perfect choice.
Old 27th August 2018, 11:58 PM   #39
Perfect, thank you for the quick reply!
Old 30th September 2018, 11:43 AM   #40
semmyroundel is offline semmyroundel  United Kingdom
Originally Posted by adason View Post
all the info is on the bottom page of diy store where you bought the boards
class A not the best way to start building amps
I would suggest few chip amps first but its up to you
Interesting, why is class A not good to start?
I've built a chip amp and a tripath, but those were on guides where I had a diagram of where everything went, rather than a schematic.
diyAudio F5 Build GuideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 1214 12th September 2019 08:23 PM
Guide to build Hypex Modules souldriver Class D 87 3rd September 2018 07:25 AM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
DIYaudio F5 V2 mounting holes sts9fan Pass Labs 1 28th February 2011 11:04 PM
Copyright ©1999-2019 diyAudio
