Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store. |
Thread Tools |
#871 |
I'm Looking for the ratings of the quasi heatsinks.
They're not rated, found this. The Amazingly DIY Friendly "Quasi Heatsinks" – diyAudio Store |
#872 |
I see dissipation numbers for the 40 mm heatsinks, but where are those data for the slimlines?
#873 | |
They're far too thin to be called "heatsinks" with a straight face. Certainly they aren't a real heatsink, so please assume they will do very little in terms of cooling! But they would be effective at drawing away a little bit of heat from a relatively cool-running component you don't want to run warm (we've seen people use them successfully with gainclones, YMMV). We aren't providing a cooling rating for them - please use your discretion when deciding what you are going to do with them. |
#874 |
For DCG3, Salas said "easily" enough dissipation with the quasi's!
The space saving is temping for a 50w apex power amp. I'll see if Apex guys can help me out. |
#875 |
There is a very, very large difference between the cooling requirements of a linestage compared to a power amp. The extrusions are not heatsinks, as Gian says.
Depending on them to have any power dissipation in a situation like that is risky.
Illustrated Build Guides - Pass F4 - Pass B1 - Pass F5 - Pearl 2 - O2 HPA - Hagerman Bugle 2 - Pass Aleph J - Me at BAF'13 -Pass F5Turbo - BA-3 Amp - BA-3 Preamp -F6- -AmpCampAmp -Me at BAF'18 -Me at BAF'19 |
#876 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Photo Discussion | cadman | Tubes / Valves | 69 | 20th February 2013 12:10 AM |
What d'you put in the PSU chassis, and what in the circuit chassis? | andyjevans | Tubes / Valves | 5 | 15th December 2007 12:41 AM |
SMPS for B+ discussion | ackcheng | Tubes / Valves | 36 | 14th November 2006 01:36 PM |
How to star ground to Chassis without a Chassis?? | Minion | Chip Amps | 10 | 5th November 2006 05:28 PM |
Where to get chassis or chassis parts in Vancouver? | Prune | Parts | 1 | 7th July 2004 06:37 PM |
New To Site? | Need Help? |
