The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Chassis Discussion
Chassis Discussion
Thread Tools
Old 25th November 2020, 01:52 PM   #861
Gianluca is offline Gianluca  Italy
Gianluca's Avatar
Yes, the slots are used by our supplier to put them in their anodizing tanks
Old 1st December 2020, 10:43 AM   #862
ukhopeful is offline ukhopeful  United Kingdom
Bravo Gianluca! Steel brackets on Dissipante now has M3 captive nuts instead of using self-tapping screws
Old 21st January 2021, 07:57 PM   #863
wtnh is online now wtnh  United States
wtnh's Avatar
Default Front panel grounding
I had a DUH! moment recently when I noticed that my digitally controlled preamp which I had built in a 2U Pesante was getting glitched by static; that is the Arduino microprocessor inside would sometimes go haywire when I touched the front panel (it is winter here and static is very present).
I have always bonded the baseplates and back panels of the chassis I use to AC ground for safety. However, I neglected to bother with the front aluminum panels, since I assumed - incorrectly - that the mounting screws would take care of it.
WRONG! The paint on the side panels is so good, that the screws are completely insulated and the front panel "floats".
Scraping the paint off of the back of one of the side flange holes and adding a star washer solves this, but you also need to do this at the rear of the enclosure as well. In fact, all painted (and anodized) metal parts need to be bonded to ground.
FWIW - hope this is helpful info.
Old 21st January 2021, 08:15 PM   #864
RussellKinder is online now RussellKinder  United States
Default Anodized aluminum
Very true. An anodized surface is aluminum oxide, which is definitely not conductive.
--Russell
Best Regards, Russell
Wherever you go, there you are. --Buckaroo Banzai
Old 27th January 2021, 06:48 PM   #865
yaduck9 is offline yaduck9  United States
I am changing out my F5 boards for an F6 and I find that the transformers on the F6 boards are a bit too close to the inputs and outputs mounted on the rear panel of the case.
Is it possible to order a new rear panel for a Deluxe 4U case?
Thanks for your time.
Bob D.
Old 27th January 2021, 07:27 PM   #866
astromo is offline astromo  Australia
astromo's Avatar
Chassis Discussion
yaduck9, check the store under chassis accessories. You should be able to find what you're after.
Old 28th January 2021, 01:53 AM   #867
The store didn't have what I needed, but I was able to source it through another vendor.
But, thanks for the quick answer.
Old 28th January 2021, 02:07 AM   #868
Joel Wesseling is offline Joel Wesseling  Canada
Joel Wesseling's Avatar
Thermal Resistance rating of the extrusions, slimline 2U, for example - Are they available?
Old 28th January 2021, 02:51 AM   #869
brian92fs is offline brian92fs  United States
brian92fs's Avatar
Chassis Discussion
The heatsinks entry has the ratings. You can also visit Modushop site. They have the ratings listing in their descriptions.
Old 28th January 2021, 11:03 AM   #870
astromo's Avatar
Chassis Discussion
Beat me Brian. Nice work.
Chassis DiscussionHide this!Advertise here!
Thread Tools
Photo Discussion cadman Tubes / Valves 69 20th February 2013 12:10 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
SMPS for B+ discussion ackcheng Tubes / Valves 36 14th November 2006 01:36 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
