The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Chassis Discussion
Chassis Discussion
Old 8th September 2019, 05:30 AM   #681
mworthin is offline mworthin
Jason, Thanks! Yes, that is it:
Pesante 2U, 4 mm aluminum front panel rack mount
Old 9th September 2019, 10:50 AM   #682
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Chassis Discussion
I purchased the Pesante 2U case from the diyaudiostore, with the intention of acid-etching the front panel (like I have done for small enclosures), but got cold feet when I received the enclosure and saw how big an area on the front panel I would have to work with.
There was a Mr Majestic thread that included the Front Panel express files for many of the other Hifi2000 store offerings, but it does not have this particular panel. I found the .dxf files on the Hifi2000 website, but the Front Panel importer is expecting just a faceplate and not the full enclosure (in fact, expects a front panel shape .dxf and a separate panel cutout .dxf file). I just get error messages. Is this available somewhere else and I am just missing it?
These would be great to have on the diyaudiostore at the time of ordering; one could work on the front panel while waiting for shipping from Italy.
My concern just doing these from my own measurements is making sure the beveled holes front panel holes line up perfectly and with the correct bevel, since this is required for the stability of the box, which will be rack mounted. I do not have graphics software for .dxf files to edit and make the conversion from the Hifi2000 files.
Thanks in advance,
Mark
Please find a DXF file attached. Both FPX and Hifi2000 work with DXF files. FPD can import this DXF, and also export your finished DXF.
Both companies provide excellent and unique services for the DIYer. I would note that Hifi2000's pricing is very competitive especially on thicker panels, so it's worth asking for a quote (the best way to do that is via contact@diyaudiostore.com). Additionally Hifi200 can can perform services like re-anodization after working the metal, and safely working on 10mm panels, that FPX presently does not. Best of luck with your build
Old 10th September 2019, 06:30 AM   #683
Thanks! I thought Hifi2000's pricing was great...I didn't know about the FPD export feature
Thank you very much!
--Mark
Old 19th November 2019, 04:06 PM   #684
airborne11b is offline airborne11b  United States
I have searched in here and other forums but could not find the answer. Is there a Deluxe 5U back panel configuration for monoblocks?
Old 19th November 2019, 07:30 PM   #685
6L6 is offline 6L6  United States
6L6's Avatar
Chassis Discussion
As a stock item? No. But Modushop could absolutely make it for you.
info@modushop.biz
What are you building, F5Turbo V3? The big monsters? Cool...
Old 19th November 2019, 08:02 PM   #686
I am building (attempting) the F5T V3 Monos! I have a goal of approx 100W of Class A. I will contact Modushop and get an estimate. Thanks!
Old 19th November 2019, 08:39 PM   #687
Gianluca is offline Gianluca  Italy
Gianluca's Avatar
As long as we get a DXF file with the position and dimensions of the holes you would like us to drill in the rear panel that's totally doable
If you don't own a CAD program feel free to contact me at the email address in post #685 and I'll show you how you can generate your own file
Old 19th November 2019, 08:45 PM   #688
Thanks Gianluca! I do have access to AutoCAD. I will put together a .dxf and be in contact with you guys.
Old 22nd November 2019, 03:31 PM   #689
alexya is offline alexya
please help me, how is the amplifier chassis assembled? I saw that photos are missing here Illustrated guide to the 4U deluxe Chassis
my chassis,,,
Old 22nd November 2019, 03:39 PM   #690
6L6's Avatar
Chassis Discussion
Steps in ACA guide are effectively identical, construction method is the same, your chassis is just bigger.
Start at step 18
Amp Camp Amp V1.6 Build Guide - diyAudio Guides
Chassis DiscussionHide this!Advertise here!
Photo Discussion cadman Tubes / Valves 69 20th February 2013 12:10 AM
What d'you put in the PSU chassis, and what in the circuit chassis? andyjevans Tubes / Valves 5 15th December 2007 12:41 AM
SMPS for B+ discussion ackcheng Tubes / Valves 36 14th November 2006 01:36 PM
How to star ground to Chassis without a Chassis?? Minion Chip Amps 10 5th November 2006 05:28 PM
Where to get chassis or chassis parts in Vancouver? Prune Parts 1 7th July 2004 06:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
