The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Mezmerize B1 Buffer Preamp
Thread Tools
Old 6th January 2021, 10:30 AM   #541
glennjarrett is offline glennjarrett  United Kingdom
Default finally got round to swapping them out
Finally got round to swapping the 10 X 2SK170BL out for the 2 X 2SK209GR on adapters 4 matched and 6 un matched
Works very good and the dc off set is lower than the 2sk170bl's so it looks like a better matched quad
sounds really good indeed
Click the image to open in full size.20210106_100534 by glenn jarrett, on Flickr
Click the image to open in full size.20210106_100454_001 by glenn jarrett, on Flickr
Click the image to open in full size.20210103_151909 by glenn jarrett, on FlickrClick the image to open in full size.dca by glenn jarrett, on Flickr
Old 6th January 2021, 10:38 AM   #542
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Very nice. Congratulations. Did you find the Peak test socket practical enough?
Old 6th January 2021, 11:15 AM   #543
Hi Salas
Happy New Year
Yes its a bit fiddly at first but i soon got the hang of it with a pair of tweezers
and a big magnifying glass
i let the fets warm up for 30 seconds then tested with 10v 100R sorted into idss groups
then soldered onto sot23 adapters then tested again with 10v 100R on breadboard 10 at a time
again once set up power on then leave them for a few minutes then measure the voltage across 100R
then ran the trace on the dca 75 a bit of a faf but worth it
would be quicker with 10x sot23 test sockets on veroboard but i cant find any and the peak ones are 20 a pop !
Old 6th January 2021, 02:35 PM   #544
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
What type of adapters did you use for those 2SK209GR ?
BTW.... splendid work you have done
RC
  Reply to this post
Mezmerize B1 Buffer PreampHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
