The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Mezmerize B1 Buffer Preamp
Old 17th January 2019, 10:07 PM   #311
batty is offline batty  Australia
Decided to use this case for mine, should go well with the M2X.
Full Aluminum Amplifier Chassis Amp Enclosure Preamp Box 425*70*313mm | eBay
I will need to drill a few more holes for the other 2 input channels, I really like the idea that it has the shielded compartment for the PSU.
Townshend Rock II, My new TT since 1986.
Old 17th January 2019, 10:10 PM   #312
pelayostyle is offline pelayostyle  United States
Haha, that's the same case I bought.
Old 18th January 2019, 05:56 AM   #313
Is it a good fit?
Old 19th January 2019, 09:15 PM   #314
joshua43214 is offline joshua43214
I have a couple of questions.
First, how much heat sinking does the Mesmerize need?
I have a 2U Slimline chassis coming this week, and I was wondering if I could mount the B1 on one of the "pseudo" heat sinks. The B1 transformer is an Antek AS1215
The chassis will hold a total 3 transformers, an Allo Katana, and 3 Salas Ultra-BiB power supplies (4 power rails). I would not go so far as to say space is at a premium, but it is a bit tight.
Second, what are people doing for wiring to the output jacks? I am debating between microphone wire, coax, and just braiding the conductors and ground from something like 22ga solid core wire. I will be able to route them away from the transformers and power supplies, I am just not sure about how much I have to worry about EFI in this situation, so I would love to hear the experience and wisdom of others on this subject.
Thanks,
-Josh
Old 19th January 2019, 10:17 PM   #315
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
2W dissipation per Mosfet i.e. 4W per side. 3mm alu chassis floor will do, not even needing the pseudo heatsink side. Unless you must mount it on the side if it fits. Or 3C/W heatsinks like FISCHER SK 81/ 50 SA, Aavid Thermalloy 0SY76/100/N etc.
I generally recommend coax and there are good quality small diameter microphone style types with two conductors and a shield from trusted manufacturers like Mogami etc.
Old 24th January 2019, 09:28 PM   #316
Not sure if this is possible or not, I was thinking of adding a second pair of output connectors in parallel with the originals so I can connect to my WHAMMY, is there anything I need to put between the 2 outputs or can I just connect wires between the 2 pairs of RCA connectors.
Cheers
Old 24th January 2019, 09:51 PM   #317
Salas's Avatar
It's been successfully done many times before by other builders. Just put 100 Ohm resistors towards the secondary outputs hot.
Old 25th January 2019, 01:05 AM   #318
Thank you.
Old 1st February 2019, 11:59 PM   #319
Chassis turned up today, very happy with it.
Old 2nd February 2019, 09:26 AM   #320
Salas's Avatar
Cool
Mezmerize B1 Buffer PreampHide this!Advertise here!
Copyright ©1999-2019 diyAudio
