Thanks Salas. Your promptness is amazing. I guess your suggestion point in using a switch after the alps potentiometer. Sounds wise.@ Gli
Its a good idea to redirect the signal with a switch so to isolate the two circuits.
The Mezmerize 2018-19 notes refer to fuses rating for 50VA own transformer.
https://cdn.shopify.com/s/files/1/1006/5046/files/Mez_TYA_018_BOM_Notes_Rev.pdf?70
soldered the 4 fets 7.46 7.44 7.49 7.55
rail voltages are +9.77v -9.74v
voltage across 2x 68R +1.957v -2.042v
dc offset 001.5v 000.7v
looks like all is well
20200213_105033 by glenn jarrett, on Flickr
Maybe it's the photo, however one of the irfp9240's could perhaps do with a bit more solder? (bottom left, middle pin)
Indeed. Maybe there is a fillet underside though. But he better touch it up with a bit of solder on the top side too.
Most builders were historically happy enough where you now stand as it was discernibly better than with 60mA when further on it just gets gradually better. That was with bigger transformer and Hypnotize single input version which had more reservoirs. With your transformer and a Mezmerize try down to 5 Ohm I would say and judge for yourself. Piggy back another 10 Ohm on each Rset is the easy way. Monitor your rectifier diodes temperature also.
Hi -- I'm also building the Mez B1, and just got to listen to music through it for the first time today! Beautiful.
Here's a quick picture of where I got today. As you can see, there's space for an internal DAC streamer which will go in there next, as soon as I get the PSU boards from Teabag. I'll post more/better pictures when I'm done.
I could not have gotten this far without this forum and all your advice, so thank you all for that, and thank you to Salas for designing this beautiful piece.
- The diyAudio Store
- Mezmerize B1 Buffer Preamp
