FS: DIY spare parts for sale. Transistors, Audio Technica ear pads, Volume knobs
I got most of the parts from Digikey and Mouser. I had big plans on making a lot of DIY stuff but the desire has diminished. If you have any questions please let me know.
Please PM me with the parts you want and your address. I will then send you a quote for the shipping cost. I can only take Paypal as payment and Credit Card via paypal is ok.
Check out my feedback here: http://www6.head-fi.org/forums/showthread.php?t=153656&referrerid=25088 and ebay feedback here: http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback&userid=buzzerbro&iid=
Item# Quantity; Part#; Description; Cost
  1. 1 pair; AT ear pads; Audio Technica ear pads. Used but in Good Condition. No tears at all. They still have a lot of life in them. Washed and ready to use. These will fit the ATH500, ATH700, or ATH900 headphones.; $20
  2. 1 pair; 414 Pads; Fits Grado Headphones. Brand New. Yellow. Never used but taken out of the package; $SOLD
  3. 15 foot; USB Cable AB; This is a brand new still in package USB cable with male A to male B connections $3
  4. 1; Knob1; Black. 38mm in diameter and 18mm high. It takes a 1/4 inch shaft with 1 set screw. $30
  5. 1; Knob2; light champagne color. 38mm in diameter and the skirt is 43.5mm in diameter and its 25mm high. It takes a 6mm shaft and it has 1 set screw. $35
    [*] 25; MJL4281A; (NPN) Brand New From Digikey $3 dollars each
    [*] 25; MJL4302A; (PNP) Brand New From Digikey $3 dollars each
    [*] 9; MJE15034; (NPN) Brand New From Digikey $1 dollars each
    [*] 9; MJE15035; (PNP) Brand New From Digikey $1 dollars each
    The highlighted parts above can be used in this sub amp design: http://sound.westhost.com/project68.htm
  6. 4; MUR860; Diode $0.50 each
  7. 4; LM3876T; Chip for chipamps $3 each
  8. 6; LM3875TF; Chip for chipamps $3 each
  9. 3; AN8005; 5 volt regulator, TO-92 $0.50 each
  10. 9; 1N4001; Diode, Free if you buy some other stuff
  11. 4; 2222 370 11155; Cap, 1.5uF, 63VDC, 10% $1 for all
  12. 1; TDA1543; Dac chip, 8-Dip $2
  13. 2; LF412ACN; Opamp, 8-Dip $2 each
  14. 1 set; 2 x LM4652TA chips, 2 x LM4651N chips, and 2 x TP0010 Thermo-pads $15
  15. 1 stereo set; chipamp1; LM3886 PCB set, consisting of 2 amplifier and 1 power supply PCB’s and 4 Holco H4 22kohm resistors. $10
  16. 1 stereo set; chipamp2; Dual mono set. LM3875TF PCB set, consisting of 2 amplifier and 2 power supply PCB’s. Chips and a couple of resistors are installed already $15
  17. 1; PS PCB; 1 power supply PCB with Rectifier diodes already installed. $5
Thanks for looking.
I would like to purchase:
Item #20 -- 1 stereo set; chipamp2; Dual mono set. LM3875TF PCB set, consisting of 2 amplifier and 2 power supply PCB’s. Chips and a couple of resistors are installed already $15
Do you take PayPal? I can pay NOW. I live in northern IL at ZIP 61111.
Please contact me through DIYaudio messaging system and when I receive your email with your PayPal address I will transmit funds and you can see my address while at PayPal.
Thanks a lot........
Dick
