I have the following for Sale:
(U) = Used; (N) = New
Electrolytic Capacitors:
6 - Nichicon Muse BIPOLAR 1000uF 25VDC Radial (U)
10- OSCON 22uF 30VDC (U)
4 - Philips 6800uF 63VDC (U)
4- Rubycon 10000uF 25V (U)
4- Nichicon KZ 1000uF 50VDC (U)
4- Nichicon Fine Gold 330uF 100VDC (U)
4- Nichicon KZ & Muse Miscellaneous Values (U)
5- Rubycon Cerafine 10 uF 100VDC (N)
5- Rubycon Cerafine 4.7 uF 100VDC (N)
5- Rubycon Cerafine 1 uF 100VDC (N)
4- Rubycon Cerafine 0.33 uF 100VDC (N)
5 - Nichicon 220uF 63VDC (N)
5 - Nichicon 100uF 63VDC (N)
5 - Nichicon 47uF 63VDC (N)
3 - Misc. 10000uF 25V (U)
2 - 4700uF 35V (U)
1- 220uF 200V (U)
1- 330uF 200V (U)
1- 2200uF 50V (U)
4 - Nichicon 470uF 10V (N)
Film Capacitors:
2 - 0.15 KP Film & Foil 630V (U)
2 - 0.68uF ERO MKP 1841 (U)
2 - Nichicon 2.2 250V PP Film (U)
Resistors:
2 - Caddock MK132 33.2K (U)
2 - Caddock MK132 1.0K (U)
2 - Caddock MK132 100 ohm (U)
1 - Caddock MK132 2.2K (U)
1 - Caddock MK132 10 ohm (U)
2 - Caddock MP-930 16W 0.5 ohm (U)
2 - Vishay VSR 33.2K (U)
1 Vishay VSR6 0.5 ohm 2 Watt (U)
10 - SEI RS1 47.5K 1 Watt Metal Oxide (N)
Semiconductors:
20 - 2N5461 (N)
20 - 2N5460 (N)
20 - MPSA06 (N)
20 -MPSA751 (N)
5 - BD139 (N)
5 - BD140 (N)
2 - NS 340AT-5V 1A Regulator (N)
2 - NS 340AT 3A Positive Adjustable Regulator (N)
6 Miscellaneous 1A Fixed Voltage Regulators (N)
1 - SMT BB D-A Converter DSD1702 (?) (N)
20 Zener Diodes Various Voltages (N)
5 1N4003 1A Diodes (N)
Switches:
1 Grayhill 12 Position 1/8"shaft Stereo Switch (i.e. Volume Control) (N)
1 Cole 12 Position 1/8"shaft Stereo Switch (i.e. Volume Control) (N)
1 Electroswitch 12 Position Mono Switch (N)
2 Power Switches 3A (U)
Miscellaneous:
4 - RCA Phono Jacks - Gold (from a Linn LK-1 PreAmp) (U)
4 - DIP Sockets - Gold Plated 8 Pin (N)
1 - DIP Socket - Gold Plated 14 Pin (N)
3 - AC Male Jacks (Accept Remale Power Cord (U)
1 - XLR Jack Female (U)
1- XLR Jack Male (U)
1 - XLR Male/Male 1 Meter Shielded Cable (U)
2 - Fuse Holders (U)
1 - Heat Sink 6"X 4" X1" Aluminum Natural (U)
1- GainClone Extra PS Board (from Peter Daniel/Brian GT) (N)
If you want a photo of all these items, I will email you.
I will sell all for $50 USD Total with free shipping to US & Canada.
Thanks,
2 - 4700uF 35V (U)
1- 220uF 200V (U)
1- 330uF 200V (U)
1- 2200uF 50V (U)
Film Capacitors:
Resistors:
Semiconductors:
20 - 2N5461 (N)
20 - 2N5460 (N)
20 - MPSA06 (N)
20 -MPSA751 (N)
5 - BD139 (N)
5 - BD140 (N)
Switches:
Miscellaneous:
Thanks,
Note:
For all the USED parts i.e. Capacitors/Resistors etc, the leads are naturally cut shorter, but are still usable for circuit Board etc.
$50 Total shipped is reasonable because my first LOT of parts which was over 8 LBS shipping weight & the cost was $22.52 CAD to Tuscon AZ.
This lot of parts will weigh about 6 lbs shipped with the cost running between $15 to $20 CAD depending on destination.
Thanks,
Dan
Thanks,
Dan
UPDATED! ADDED MULTI CAP & Solen Caps and Other Interesting Stuff!
Found Some more Parts to sweeten the Deal!
Add to the First List for NO EXTRA COST!
2- Solen 0.22uF 630V PPE022 (N)
2 - Multi Caps 0.22 uf Metalized PP (MPPX) (U)
3 - More XLR Jacks - FEMALE (U)
2 - Shielded 5 Foot Long XLR-MALE one end & Female AC Plug Other End (U)
2 - BB DSD 1791DB 24 Bit D/A Converters (N)
14 - MPS 651 TO-92 Transistors (N)
50 MORE- Various Elect Capacitors - OSCON's/ F type Black Gates (U)/ Panasonic FA's etc (Mostly Used)
5 - Various Switches - Power etc. (U)
Some Motorola MUR 860's & MUR460's (N)
Bunch of Resistors (N)
4-5 Control Knobs - Satin Finish and Plastic (N & U)
5 Ft Length 8MM OFC Interconnect Cable (N)
1 Spring Loaded Fuse Holder (N)
2 - 4700uF 35V (U)
1- 220uF 200V (U)
1- 330uF 200V (U)
1- 2200uF 50V (U)
Film Capacitors:
Resistors:
Semiconductors:
20 - 2N5461 (N)
20 - 2N5460 (N)
20 - MPSA06 (N)
20 -MPSA751 (N)
5 - BD139 (N)
5 - BD140 (N)
Switches:
Miscellaneous:
2 - 4700uF 35V (U)
1- 220uF 200V (U)
1- 330uF 200V (U)
1- 2200uF 50V (U)
Film Capacitors:
Resistors:
Semiconductors:
20 - 2N5461 (N)
20 - 2N5460 (N)
20 - MPSA06 (N)
20 -MPSA751 (N)
5 - BD139 (N)
5 - BD140 (N)
Switches:
Miscellaneous:
