DIY D1 I/V Stage from Pass Dac PCBs for sale
This is what the prototype boards look like.
I have been using them for almost a year now and they work superb.
The sound is fantastic.
The difference with the new ones will be a few small corrections in the positioning but they are the same.
There will be a top print for the placement of the parts which was not the case in the first ones.
Each board has to circuits on it.
In the schematic the identical parts are marked with A and B.
Only 2 resistors and 2 capacitors are common for the 2.
That means that if you want stereo singel ended output you need one board from each. 1 Main board and one power supply.
If you want a stereo balanced output you need 2 boards from each.
2 main boards and 2 power supplies.
hello !!!
I am interested in a set of boards - two of each. pls email me at nguoi_votu@yahoo.com and how much it would be I am from California
