I sell three different condenser microphone amplifier modules for Chinese BM-700, BM-800 or similar microphone body on eBay:
Compatible capsule: 34mm condenser capsule or 25mm electret (without built-in JFET). Required 48V phantom power.
You can also buy assembled microphones on eBay:
I have only replaced the occasional FET in condenser mics. But when I see failure prone caps used when they
don't have to be, I speak up. You don't like it as is your right. I did suggest a solution which you probably don't
like polymer caps as is also your right.
I've been repairing electronics over 50 years and have seen many things, some brilliant and some dumb.
G²
G²
stratus46, the ripple current of these capacitors is less than 3 mA. At this current, they will last for decades, just like polymer capacitors. But beyond that, electrolytic capacitors have the correct ESR for audio depending on the frequency.
This is not a question of what I like, this is the only correct solution.
