Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS Quantity of five JLester TPA3255 and power supplies MAKE ME AN OFFER!
Thread Tools
Old 21st April 2021, 09:13 PM   #1
stretchneck is offline stretchneck  United Kingdom
Default FS Quantity of five JLester TPA3255 and power supplies MAKE ME AN OFFER!
Up for sale, a total of five pairs of unfinished TPA3255 amp boards and power supplies. All brand new. MAKE ME AN OFFER!
Each pair includes
One TICORE260BTL TPA3255 STEREO PFFB 48V (PARTIAL KIT) AMPLIFIER MODULE with the four premium coilcraft VER2923-103KL inductors installed.
One AliExpress 800w 48v low noise power supply (KAYPW Switching Power Supply Light Transformer, as used by XRK on his builds)
FS Quantity of five JLester TPA3255 and power supplies MAKE ME AN OFFER!-tpa3255-board-jpg
FS Quantity of five JLester TPA3255 and power supplies MAKE ME AN OFFER!-800w-power-supply-jpg
To complete each amp board all you needs is:
One ATS-TI1OP-519-C1-R3 heatsink (available on mouser, costs just over 5)
2 pcs OPA1656 or LME49860 on SOIC-8 to DIP-8 adapter ENIG PCB - readily available on the internet
4pc tank caps: 1800uF 63V low impedance (e.g. panasonic EEU-FC1J182, about 2 each)
Plus other ancillaries and chassis etc... which are not included.
You will need to make the following easy amend to the boards as TICore260BTL Version "V1A" has a small fault that when right channel exceeds certain power output, the module goes into protection mode. This is overcome by lifting C17, then connect the ground of C17 to ground plane on C16. (Picture attached)
Good performance from these. Any questions please ask.
Gavin
Oxford, UK
Old 22nd April 2021, 09:40 AM   #2
reddish75 is offline reddish75  United Kingdom
Hi Gavin,
Shoot me a price via pm for one that I can't turn down.
Chris
Old 22nd April 2021, 01:03 PM   #3
Should have asked this before, can a pre be used with these?
Old 22nd April 2021, 01:06 PM   #4
Yes of course - active for, perhaps better a passive
Old 22nd April 2021, 01:17 PM   #5
Would be an active, a Sony ta-e901 just for testing.
Did you have a chassis in mind for these?
Old 22nd April 2021, 01:52 PM   #6
The amp modules will work with any preamp, but some active preamps may have too much gain (meaning only using a small proportion of the volume range available). Perfectly fine for testing though. Passive preamps can also be sourced very cheaply, you can also use software volume control (but be careful).
Chassis - Cheap ones from RScomponents or Audiophonics (probably not as popular now that Audiophonics require a minimum order of 150 post-Brexit).
Old 23rd April 2021, 10:17 PM   #7
3 pairs sold - 2 remaining
Old 24th April 2021, 06:30 AM   #8
By the way, PSU is 170-250v, so no good for America. But I will sell the amp modules separately.
Old 26th April 2021, 11:01 AM   #9
1 pair left!
Old 26th April 2021, 12:15 PM   #10
ml48 is offline ml48  United Kingdom
How much would the last pair cost sent to West Sussex,thanks.
FS Quantity of five JLester TPA3255 and power supplies MAKE ME AN OFFER!Hide this!Advertise here!
Thread Tools
FS JLester TPA3255 48v passive post filter feedback amps and power supplies 99 each stretchneck Swap Meet 5 19th April 2021 03:12 PM
FS: 813 tubes and sockets - make offer! andyjevans Swap Meet 0 19th August 2011 07:39 PM
F&T Dual Section Box Quantity Special Offer MCampbell Vendor's Bazaar 0 2nd June 2009 07:10 PM
Five-BJT low power headphone amp linuxguru Headphone Systems 26 20th August 2008 12:26 PM
Two 850136 Peerless woofers fs, Prefer Adelaide pickup, $150 the pair, or make offer. SkinnyBoy Swap Meet 19 1st May 2004 02:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
