Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
wanted Tda 2052v audio amp ic
Old 16th October 2018, 11:22 PM   #1
Greg32 is offline Greg32  Australia
Default wanted Tda 2052v audio amp ic
Hi as the title says Im looking for a single tda2052 ic for a repair. I cant find any locally. Greg
Old 17th October 2018, 07:42 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
That is because they have been obsolete for years.
There may be some to be had on fleabay; tda2052v | eBay
I was asked to supply one, that I purchased from a fleabay supplier, for a faulty powered monitor and the original was not faulty. The black glue used to hold the components in place, was electrically conductive.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 17th October 2018, 10:29 AM   #3
Thanks Jon, yes this is a krk powered monitor it also has liberal amounts of a black goo over a lot of components. The unit is functioning but sounds lousy. The scope shows only a +ve swing on the hf (tda2052) I've replaced tl074. With no change to issue. Greg
Old 18th October 2018, 05:43 AM   #4
Problem now solved, black goo on the board had corroded 2 resistors into open circuit. no issues with the tda2052 now.
wanted Tda 2052v audio amp icHide this!Advertise here!
Wanted: FDA-1 FET-Audio DAC MEnsing Swap Meet 4 22nd March 2015 12:23 PM
Wanted: Wanted to buy california Audio Lab Tempest II Special Edition Power Supply Un ebxb Swap Meet 0 22nd February 2012 03:51 PM
Wanted:LC Audio zapfilter..new or used Chilli6565 Swap Meet 0 7th May 2009 06:25 AM
Wanted: 0.33F MKP, 1R8 Mox or audio... Malefoda Vendor's Bazaar 0 29th April 2008 02:04 PM
Please audio-help wanted! kekropas Analogue Source 4 7th June 2004 06:16 AM
