TOKIN SITs- Pairs of THF-51S and 2SK182ES
Joined 2009
I bought over the last years some SITs from eBay watanabetomoaki.
This was a time where no matching for a pair was offered.
Meanwhile I have two pairs from Chul and one pair from pras1170 I can use for my build, so I have too much!
I just looked what I had in my basement and found two good pairs and one mediocre (and two singles).
These pairs will work for instance in Zen Mods SissySIT circuit.
So I offer here, measured in the Locky-z curve-tracer at Id = 2A and Vds = 24V
1. Pair THF-51S numbered 8 and 10, Vgs = 2,64/2,64V, perfect match
price 60 €
2. Pair THF-51S numbered 1 and 7, Vgs = 2,3/2,35V, near to perfect
price 55 €
3. Pair 2SK182ES numbered 6 and 5, Vgs = 3,2/2,9V
price 45 €
As I already told these pairs should work in Zen Mods SissySit Circuit.
Postal fees worldwide 8.-€
You will find the pairs in the picture.
The solder on the pins is only from fixing the curve-tracer wires, they were all not yet used.
Joined 2007
price 60 €
price 55 €
price 45 €
Hi Generg, have you done your measurements with warm SITs or cold one? When I do the same measures with cold sits, I get Vgs below1V with the Locky_z curve tracer.
Ernst
Joined 2007
I have no explanation for your low values......
What did the vendor say they should be?
If you want send me one and I test it in my tracer and we see what happens.
They are from watanabetomoaki. They have marked 1.5 to 1.7 on their back, which would reflect Vgs at 1000mA.
What I would like to know, if your tests were done with cold Sits or heated Sits. If cold, than mine would really be different.
I think you do have a few from the same source. What was written on the back?
Joined 2012
When I asked about the numbers written on the back of the THF-51Ss that I purchased from watanabetomoaki, he wrote back:
"The written numbers on them means Id (A), at Vds=25V Vgs=-1V aroun 25 degree".
So 1.5 and 1.7 are Id (A) at Vgs=-1V. Also he reversed the Drain and Source for his test at Vgs=-1V.
Joined 2012
I purchased four THF-51S. I tested them on a heat sink at Vds=24.0V, Id=1.8A:
Written on Back........Vgs
2.2.......................-3.11V
2.4.......................-3.19V
2.5.......................-4.46V
2.5.......................-3.54V
So I then tested the third one with Vgs=-4.46V the watanabeaoki way but on a heatsink so at a higher temperature than 25C:
Vsd=25V, Vgs(actually g to d)=-1.0V, and I=2.27A which is close to 2.5A written on the bottom.
So with one pair the match was good, but with the supposedly "perfect" pair the match was way off.
