Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: one pair of Nelson Pass A40 PCBs
FS: one pair of Nelson Pass A40 PCBs Please consider donating to help us continue to serve you.
Old 28th October 2019, 05:32 PM   #21
alexcp is offline alexcp  United States
alexcp's Avatar
The power supply for the A40 is probably best built along the lines of the original article.
Since it is Class A, it draws a lot of current - about 1.5A per rail per channel - all the time. You will need a 250VA or better, 2x22V power transformer for each channel. One possible option in Europe is Amplimo type 78015 or 77015, rated for 300VA. A 25A+, 100V+ bridge rectifier and a pair of large - say 22,000uf @ 50V+ capacitors (if you feel like spending money, consider Mundorf HC type) - will complete the power supply for one channel. If you feel like spending even more, consider CLC filtering with another pair of capacitors and a pair of chokes in between for each channel.
Old 29th October 2019, 06:19 AM   #22
gary s is offline gary s  Australia
Alex, some questions for you.
1. You mention you have added a Zobel network as can be seen on the pcb artwork in post #13, C5 is 0.1uF but I cant read what value/rating the resistor is shown as R16 (Note, R16 on original schematic is an emitter resistor for output transistor Q7)
2. In post #17 you show a photo of the pcb, but the Zobel network components are not on that pcb - so I am assuming that is not the latest correct photo.
3. Also the Zobel network components are not on the Mouser project as far as I can see that you linked.
Old 29th October 2019, 05:51 PM   #23
alexcp's Avatar
Gary,
Apologies for confusion here. The new boards have no Zobel network, as it was not implemented on the Nelson Pass’ board design as per the original article. The photos in post #17 are correct.
The confusion stems from the fact that my original boards, made years ago and shown in the photos attached to post #1, did have the zobel network implemented (R16/C5 on the silkscreen; should have been R20/C5). The motivation was that the board for the A75 has it, and there was some space available. For the new board, however, I reverted to the original design.
The shared project at Mouser has the resistor for the zobel network (R20, 10ohm 1W), but it seems the capacitor (C5, 0.1uF 100V) has vanished from the list. Sorry about this; I will update the project.
Old 29th October 2019, 07:16 PM   #24
finwbu is online now finwbu  Finland
finwbu's Avatar
Dear Alexcp
Please would you send me 4 pair of your PCB A40 to me?
Can i pay you with PayPal?
I will send you a private message.
Walter
Old 29th October 2019, 10:00 PM   #25
Hi Alex,
Thanks for clearing up the confusion on my questions. One can always add the Zobel network off the pcb.
Did you implement the Zobel network in your latest A40 build or leave it out?
Gary..
Old 30th October 2019, 01:48 AM   #26
alexcp's Avatar
Default Q11 pinout error in post #20 schematic
I spotted an error in my schematic in post #20 above - the LM334 current source is connected incorrectly. I am sorry I did not spot this one earlier.
In the schematic from post #20, the junction of D1, R8 and the base of Q3 is connected to the adjustment pin of LM334. It should be connected to the V- terminal - see the attached pictures. Because of that, when using LM334 as Q11 with the PCB, its adjustment pin and V- pin must be crossed. I apologize for this.
The markings "D G S" on the PCB are correct, and if you use a JFET or a depletion mode MOSFET as the current source, you can plug it in according to those markings.
On a positive note, you can use DN2540 depletion mode MOSFET in TO-92 package as Q11 on the PCB. Its pinout is "S G D", so it goes into the PCB with the flat side towards R8, not R9. I will post photos over the next couple of days.
Old 30th October 2019, 03:05 AM   #27
Hi Alex,
Thanks for the correction here on Q11, you should correct the schematic with a revision # and repost that, referencing your post above and photo's so there in no ongoing confusion.
Gary..
Old 30th October 2019, 04:02 AM   #28
alexcp's Avatar
Thank you Gary for the suggestion. Here it is:
This schematic corrects the error described in the post #26 above and replaces the schematic attached to post #20.
It also adds information on using LM334, DN2540N3, and J111/112/113 in place of Q11. Note that using a MOSFET or JFET as Q11, you need to determine the value of R9 experimentally, so that it sets the current thorough Q11 at 2..3mA.
Old 30th October 2019, 04:23 AM   #29
That was quick Alex, your revised schematic should be handy for all with those options.
Any clues as to what value to start with for R9 using the LM334 - I assume your testing will have you settled on a value - or are you still testing late at night there?
Old 30th October 2019, 04:40 AM   #30
alexcp's Avatar
Unlike FETs, LM334 is predictable, and for it R9 can be calculated using the formula from the datasheet. The formula gives about 22ohm for 3mA and 33ohm for 2mA. I will test it IRL and report.
FS: one pair of Nelson Pass A40 PCBsHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 9 19th October 2019 07:47 PM
FS: Nelson Pass "VFET2" Front End PCBs luvdunhill Swap Meet 35 26th June 2017 10:21 AM
Wanted: Pass F5 clone pcbs & psu pcbs Renton76 Swap Meet 2 25th March 2013 11:26 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Nelson Pass macka Pass Labs 6 31st May 2002 01:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
