Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: one pair of Nelson Pass A40 PCBs
Old 20th April 2018, 03:19 AM   #11
alexcp is offline alexcp  United States
alexcp's Avatar
Just sent you a PM.
Originally Posted by Freecrowder View Post
If there are boards still available I would like a pair.
let me know how to proceed.
Thank you
Old 19th June 2018, 01:21 PM   #12
Freecrowder is offline Freecrowder  United States
If I'm correct there are some differences in this board vs. the original boards in the first article? The extra ground connection and possible artwork around the FET.
Old 19th June 2018, 03:34 PM   #13
alexcp's Avatar
Yes, you're right - thank you for spotting it.
There are two minor differences.
First, the original board uses the Source-Drain-Gate (SDG) pinout for the JFET, while my board uses the GSD pinout, which matches the LM334 current source that I used. As Nelson Pass wrote in "Part Substitution", his second article on A40: "note that the source pin of the Jfet is attached to R9, and there has been some confusion about that, with some different pinouts on the 2N5248".
Second, I added a Zobel network to the board, which has that extra GND terminal. Its other end is connected to the FB terminal (the right side of R5). The whole thing can be left out.
I attach the artwork copied from the original "The A40 Power Amplifier" article by Nelson Pass and the artwork of my board for comparison.
Old 20th June 2018, 06:00 PM   #14
Eric is offline Eric  United States
Eric's Avatar
Here is the document from Audio Amateur about the PCBs and the schematic.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 20th June 2018, 07:01 PM   #15
alexcp's Avatar
Thank you Eric! Yours is a curious document.
It concerns the PCB that (I understand) was being sold in 1997. The amplifier input network includes the usual (although some say harmful to stereo imaging) low pass filter. The original article says:
... we start with C1 forming an input rolloff filter in conjunction with the typical 600 Ohm to 1k Ohm source impedance. Lower frequency rolloffs can be achieved using higher capacitance values and higher source resistance values.
However, the board mentioned in the document you provided was made inconsistent with the schematic and the above description: the rolloff filter was formed by C1, the source impedance, and R1. Not a big deal, but still an inconsistency.
My boards (which I still have a few left, BTW) are consistent with the schematic, including the input rolloff filter and the Zobel network, which is on the schematic but not on the original board.
Old 20th June 2018, 09:38 PM   #16
Eric's Avatar
Ah - I did more of a side-by-side comparison between the two circuits that you posted and spotted the differences. They appear to be fairly minimal. In the boards that I have, there was a trace error for which a correction was issued. At some point, Nelson indicated that the difference in the PCB from Audio Amateur was mostly irrelevant. Since I was unable to open the Gerber file you posted, I wasn't sure of the source for your board.
Either way, this is still a nice amp!
Old 21st October 2019, 05:47 PM   #17
alexcp's Avatar
Default New batch of A40 boards arrived
UPDATE: a new batch of A40 PCBs arrived. Unlike my first boards, these are double sided (eliminating the need for one wire jumper) with plated-through holes and solder mask and silkscreen on both sides.
These boards also follow the original article more closely; the only difference is the pinout of Q11, providing for the use of LM334 as the current source.
The price is the same: US$10 per pair of boards plus shipping.
PM me if interested.
Old 27th October 2019, 02:29 PM   #18
mauric is offline mauric
Default please you send me 1 pair to Switzerland?
Dear Alexcp
Please would you send me one pair of your PCB A40 to me?
i will pay you with PayPal?
mauric@gmx.ch
Mauri
Old 27th October 2019, 03:51 PM   #19
alexcp's Avatar
Sent you a PM.
Old 27th October 2019, 04:40 PM   #20
alexcp's Avatar
Attached is the schematic for the board only. The only difference from the original article's is that Q11 is replaced with an LM334 current source and R9 is adjusted accordingly.
Also, here is shared project at Mouser. It has all parts for one channel, including the output power Darlingtons, but not the power supply. All parts are currently available at Mouser. The project is just to give some guidance - if you wanted to build A40 for some time, you probably have some parts already.
FS: one pair of Nelson Pass A40 PCBsHide this!Advertise here!
FS: Nelson Pass "CSX1/2" "Buffered F6" Front End PCBs luvdunhill Swap Meet 9 19th October 2019 07:47 PM
FS: Nelson Pass "VFET2" Front End PCBs luvdunhill Swap Meet 35 26th June 2017 10:21 AM
Wanted: Pass F5 clone pcbs & psu pcbs Renton76 Swap Meet 2 25th March 2013 11:26 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 01:39 AM
Nelson Pass macka Pass Labs 6 31st May 2002 01:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
