I have changed my DAC and don't need the exaU2I anymore. It is in perfect working condition. I can email the custom drivers to the buyer.
• Sampling frequencies (kHz): 44.1, 48, 88.2, 96, 176.4, 192, 352.8
• Resolution (bits): 16, 24, 32
• 8, 4 or 2 channels for sampling rates up to 192 kHz
• 4 or 2 channels for 352.8 kHz
• Galvanic isolation between the USB ground and the I2S outputs.
• Two quartz oscillators for the 44.1 kHz and 48 kHz sampling rate groups
• FPGA implementation
• 256 kB FIFO buffer to support asynchronous operation
• Two analogue voltage regulators with filters
• Sample rate LED indicators
• USB power LED indicator
• Buffer level LED indicator
• Four I2S data outputs (8 channels) powered by the DAC power supply (3.3V or 5V)
• USB 2.0 interface, Mini USB connector
• Proprietary bit-perfect ASIO driver completely independent from the Windows sound system; No software volume control or mixing.
• ASIO driver implements automatic sampling rate switching; no re-sampling
Located in Sydney Australia. Will ship anywhere in the world. Price : 200 USD including shipping
