Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Hypex Ncore 2x250W Stereo amplifier
Old 30th January 2018, 07:40 AM   #11
UltraFidelity is offline UltraFidelity  United States
Originally Posted by meb46 View Post
Great project... one question, how did you wire up the LED and power supply enable circuit. I have a NC502MP and havenít quite figured out the wording to actually wire in a switch and LED yet. Any help would be appreciated!
You will need to use a voltage divider and latching switch. 2 10k resistors will do the trick for the pos power...the switch then is connected to the amp enable and the 5v rail to put it in and take it out of standby...I can show you how with pics and point out the pins if you like.
Old 30th January 2018, 08:41 AM   #12
Leeuwarden is offline Leeuwarden  Netherlands
Look at page 12 from the datasheet, 6.2 H Bus connector. Switch between J6.3 and J6.9. A led can be fed by J6.1 and J6.4.
Old 30th January 2018, 09:25 AM   #13
Forgot to mention you might need a resistor to make the led shine less bright.
Old 30th January 2018, 10:17 AM   #14
raelman is offline raelman  Spain
The easiest way:
LED:
J6.1 is +12 V (in fact, about 15V)
J6.4 Led GND
POWER ON:
Bridge J6.3 to J6.9
Attached you will find a picture
imagenes x gratis[/QUOTE]
Old 30th January 2018, 11:26 AM   #15
As far as I know it is wise to use a switch between J6.3 and J6.9 because part of the power supply stay's under power. I was told this increases the lifespan of the power supply.
Old 30th January 2018, 11:30 AM   #16
I use a switch in the main power. So no power looses
Obviously you can place a switch between J6.3 and J6.9 but then the PS will be in standby mode.
Old 30th January 2018, 11:34 AM   #17
That's right. And putting the power supply in stand by is healthier for the amp. At least, that is what I was told. But of course everybody can make their own decision what method to use.
Old 17th January 2019, 04:28 PM   #18
smallangryboy is offline smallangryboy  United Kingdom
Can I ask where you got the connector kit for the NC252MP? Specifically the molex connectors for the signal in and speaker output?
Cheers
Old 17th January 2019, 04:31 PM   #19
Cheers
Hypex.
Old 17th January 2019, 04:43 PM   #20
Digikey sells the JST connectors.
If you download the specs sheet for the amp you will see JST reference for the onboard connector.
With the reference you can seek at digikey and at the bottom of the page the male conmector as well as pinouts will appear
Hypex Ncore 2x250W Stereo amplifierHide this!Advertise here!
FS: Hypex Ncore Nc400 Stereo System raelman Swap Meet 2 2nd January 2017 08:32 PM
FS: Hypex NCore NC400 SMPS600 SiliconRay enclosure monoblock Class D amplifier pair Jaded Swap Meet 2 12th December 2016 02:54 PM
Hypex nCore/UCD transconductance - Current Output - amplifier ChrisPa Class D 23 6th August 2016 02:28 AM
FS: NEW Hypex Ncore NC500 Monoblock 700 Watt Power Amplifier (Pair) $1495 signalbeach Swap Meet 0 23rd July 2016 07:42 PM
(FS) Hypex nCore 400 amplifier marginwalker Swap Meet 10 23rd February 2014 07:04 AM
Copyright ©1999-2019 diyAudio
