FS: Es9038 PRO DAC - Design by Andrea Ciuffoli-Quang Hao Based on the ESS Sabre32 Ref
SOLD - Es9038 PRO DAC - Design by Andrea Ciuffoli- on the ESS Sabre32 Ref
SOLD - Es9038 PRO DAC - Design by Andrea Ciuffoli-Quang Hao
Based on the ESS Sabre32 Reference (ES9038PRO) DAC chip
http://www.diyaudio.com/forums/swap-meet/swap-meet/group...ro-gr-2-a.html
Support 44,88,96,192,352,384KHz PCM and DSD to play SACD ISO.
Full ground isolation from USB module.
On board reference 100MHz Crystek oscillator with a jitter of 0.5psecUltra fast oscillator buffer.
NEW!!!
DAC module assembled and tested with all components:
- ES9038PRO chip,
- CCHD-575 Ultra-Low Phase Noise Crystal Oscillator: Ultra-low phase noise CMOS oscillator provides 168-dBc/Hz noise floor | Electronics EETimes
- 7 x LT3042 linear power supply regulator 1uV noise
- 5 x LT1117 linear power supply regulator.
- All input connectors
- BUT NO OUTPUT STAGE
Original price 400$ but I'm looking for xxx + delivery.
NEW!!!
Thank you
Just a stupid question, why do you want US$, you lose on two exchanges. One the buyer needs dollars (If he is not from the USA) then you need GBP because you can't use US$. If your price was GDP you have the least trouble and its up to the buyer to make the exchange, it is in your home currency.
