Acoustic Elegance AE TD15M 4 ohm quad (4) of 15" high efficient drivers / woofers
Hi
i am selling a quad of AE TD15m 4 ohm in good condition , see photos .
one of the drivers was originally an 8 ohm driver and got re-coned for 4 ohm , the color of the magnet looks slightly different also , (photos).
all drivers are within specs as posted on the acoustic elegance web page .
i am going back to a midbass horn which is why i am selling , great drivers.
$1000 for all four plus shipping and paypal fees
i will consider selling in pairs also , $550 for the pair .
Fs: 34.7Hz
Qms: 5.09
Vas: 312 L
Cms: .3 mm/N
Mms: 70 g
Rms: 3 kg/S
Xmax: 6 mm(peak)
Xmech: 10 mm(peak)
Sd: 855 sqcm
Vd: 1.02L (p-p)
Qes: .35
Re: 3.2 ohm
Le: .2 mH
Z: 4 ohm
Bl: 11.81 T/m
Pe: 500W (cont.)
Qts: .33
1WSPL: 97.7 dB
2.83V: 101.7 dB
http://img.usaudiomart.com/uploads/...-4-ohm-quad-4-of-15-high-efficient-driver.jpg
Hi
Fs: 34.7Hz
Qms: 5.09
Vas: 312 L
Cms: .3 mm/N
Mms: 70 g
Rms: 3 kg/S
Xmax: 6 mm(peak)
Xmech: 10 mm(peak)
Sd: 855 sqcm
Vd: 1.02L (p-p)
Qes: .35
Re: 3.2 ohm
Le: .2 mH
Z: 4 ohm
Bl: 11.81 T/m
Pe: 500W (cont.)
Qts: .33
1WSPL: 97.7 dB
2.83V: 101.7 dB
