Thank you. They are on their way.
I have 4 "fixed" and two "mistake" boards left. Usual policy - first pay first ship
Luvdunhill sent me a few of the 'mistake' boards a while back - and likely more than I will use, so if/when they run out, let me know.
I prefer to send two invoices. This allows me to operate in a first come first served basis. It's easy - just send the purchase price when you express interest, if there are items left I accept the payment, send the item and request the remainder. Dunno, makes sense to me.
Ok, 2 fixed, 2 need fixin' are left.
Enough ! Insulting posts deleted.
May I remind you both that the rules clearly state that any transactions are done at the buyer and sellers own risk. The forum is not responsible if things don't work out or you have disagreements.
I suggest you both take your differences over to private email. Any more such insults posted on the forum will see bin time for those involved.
Here is the CSX2/F6 ish FE
Here is a small discrete buffer that can be used in front of the transformer:
... and an example of a regulator that can also be used with this PCB:
Prototypes should be here soon - same price / process as the VFET2 FE boards.
FS: Nelson Pass "VFET2" Front End PCBs
I can post the schematic / BOM for interested parties. Footprint and I/O to the output stage is the same as VFET2 - the idea is they can be swapped. A large number of transformers are supported, as the Lundahl's share pinouts across a lot of their extensive line. I can post a comprehensive list if people are interested. Enjoy!
Boards have been posted here:
http://www.diyaudio.com/forums/swap...n-pass-csx1-2-buffered-f6-front-end-pcbs.html
Hi
zalo 84962174669
Vuongan ở đâu? Kết bạn fb https://www.facebook.com/anberrymailHow much are you have Boad "fixed" and "mistake" ?
zalo 84962174669
