Now that all my Denon MCs are gone, I won't get around to putting this together.
Anyone who has ever listened to a DL-103 with a pair of Cinemag 3440a's knows how involving and full the tone can be. With the Cinemag 1131's the results are even better. The CM-1254's are wound using the same recipe as the 1131's, the only difference being that Cinemag's David Geren winds the 1131's himself. Although David doesn't wind the 1254's, he does personally inspect and test each 1254 that Cinemag produces.
So, what's on offer (all brand new) is this:
1 pair of Cinemag 1254 phono transformers (threaded bushing style).
3 pairs of WBT 0201 RCA jacks (pure copper, spring-loaded contact; heavy 24 carat gold plating; teflon insulation).
1 Cardas ground post (non-magnetic eutectic brass, rhodium over silver plate).
1 NKK DPDT On-Off-On mini toggle switch (with silver contacts and silver solder lugs).
1 Hammond diecast aluminum alloy enclosure (for EMI/RFI shielding).
1 foot of 22 ga. soft-annealed solid-silver wire, and teflon tubing to match (not pictured).
$499 + postage. No paypal fee.
