Still have 6 of these 10" drivers left. As seen here:
http://www.diyaudio.com/forums/swap...m-nice-quality-drivers-diy-4.html#post4352459
Also adding the following classic AR tweeters:
I don't know exactly which models these go to, but here ya go!
$20 each, shipped.
1-2151050 - 3/4" cloth dome tweeter. DCR=4.0 ohm. Round magnet. One of the leads is shorter than the other. Tested.
1-2051050 - 3/4" cloth dome tweeter. DCR=3.2 ohm. Square magnet. Tested.
1-215130-0A - 3/4" cloth dome tweeter. DCR=3.9 ohm. Large round magnet. Tested. Dome has a crease in it, but the coil lines up properly. Once mounted on a face plate, it will be fine.
1-215130-0A - Same as above, but without the cosmetic issues.
Pictures:
1-2151050
1-2051050
1-215130-0A w cosmetic issue
1-215130-0A
$20 each, shipped.
Pictures:
1-2151050
1-2051050
1-215130-0A
Next up...
Acoustic Research AR P and PS Series dome tweeters. They also sound quite good. Shielded. New old stock. I have maybe 10 or so pairs of these.
Model: 370000, T25si
$30/pr Shipped....
Specs from testing, YMMV:
Fs = 1439 Hz
Re = 5.28 ohm
Zmax = 7.85 ohm
Qms = 0.981
Qes = 2.008
Qts = .757
Le = .058 mH @ 10 KHz
Hi
i need 1piece
