Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
DAC ADLABS RD2 SE
DAC ADLABS RD2 SE
Old 12th September 2014, 08:46 PM   #1
cristi289 is offline cristi289  Romania
cristi289's Avatar
Send a message via Yahoo to cristi289
Default DAC ADLABS RD2 SE
AD LABS RD-2SE DAC Features:
32 kHz to 192 kHz (16-24 bit) input sampling frequency
Input type : optical, coaxial
Very short signal path
Ultra low jitter reference oscillator
Fully discrete transimpedance I/V stage
Black anodised aluminium case
The design philosophy of the RD-2se is concentrated on the following key-points : multiple input frequencies/bit depths and ultra accurate d/a conversion, fully discrete i/v conversion and output stage, jitter immunity regardless of the quality of the source. To achieve that a careful implementation of one of the best icís available was realised into a very compact design.
The digital signal is routed to flagship SRC4392 input receiver. Beside s/pdif reception, this IC performs both upsampling and jitter reduction, being clocked by a ultra-low jitter master XO. The upsampled signal are going into PCM1796 digital to analog converter which we found that, properly implemented, delivers one of the best sonics available.
Extensive LC power conditioning combined with active shunt regulation delivers clean supplies to digital and analog stages. In respect with phase accuracy very gentle filtering is applied to the signal, and no global feedback is present. The output buffer runs in single-ended class A for optimal musical performance.
Overall Specifications:
- Input sample rate 32 to 192 KHz
- Inputs: SP/DIF and Optical
- Outputs : RCA
- Output impedance : 20 ohms
- Harmonic Distortion + Noise 0.005%
- Dynamic Range 123 dB
- Dimensions (W x H x D) 110 x 45 x 220 mm
PRICE: 200 euro including shipping to EU.
Old 13th September 2014, 02:30 PM   #2
cristi289's Avatar
Price update:
180 euro including shipping to EU.
If it is taken with the USB - SPDIF converter Musical Fidelity V-link 192, I will give an digital interconnect cable as a gift ...
Old 14th September 2014, 09:44 AM   #3
cristi289's Avatar
Final price:
170 euro including shipping to EU.
Old 15th September 2014, 05:52 PM   #4
cristi289's Avatar
Old 16th September 2014, 06:22 PM   #5
cristi289's Avatar
bump.
Old 18th September 2014, 09:10 PM   #6
cristi289's Avatar
Sold.
  Reply to this post
DAC ADLABS RD2 SEHide this!Advertise here!
Build thread - building the Subbu DAC V3 SE bcmbob Digital Line Level 1341 13th January 2020 06:43 PM
FS:Assembled Subbu DAC V3 SE jcastellano Swap Meet 3 21st August 2014 09:18 AM
FS: Buffalo DAC SE + OTTO II malarkey Swap Meet 1 25th February 2014 08:00 PM
V3 tube-lover SE TDA1541 DAC bakus11 Swap Meet 3 21st April 2010 05:30 PM
Tube-lover SE and Full Balance TDA1541a DAC SamL Digital Source 155 23rd November 2009 12:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
