FS: Speaker building parts
VIFA P11 wg -00-8 ohm $25 ea + shipping
Parts express New Sub Woofer Amp 250 watt bass boost $85 + shipping
250w Subwoofer Amplifier W/bass Boost
This high performance amplifier has all the power and advanced features that you have been looking for! The adjustable phase control provides flexibility in subwoofer room placement.
It allows the user to "shift" the phase and fine tune the subwoofers output to their particular room environment. Until now, this feature was only found on high-end subwoofer systems costing thousands of dollars!
Specifications: Measured power output: 180 watts RMS into 8 ohms @ .1% THD, 272 watts into 4 ohms @ 0.2% THD. Signal to noise ratio: 101dB (A-weighted). Dimensions: 10-3/8" W x 10-7/16" H x 3-1/4" D. Enclosure cut out: 9" W x 9-1/4" H. Voltage: Selectable, 115/230V, 50-60 Hz, 450W. Net weight: 12 lbs.
Many things to list here
The Tiles in Perspective for the pictures is 6 inches
Capacitor - Resistor - Coils Priced at Parts Express is over $2000.00
99% of all this is new only the Vifa drivers, a few of the Aeon resistor and caps are used. I'll take offers on any group of speaker building pieces
All of the CAP's, Coils & Resistors i'll take offers on to sell as a group.
Clarity SA Audio Capacitors
4.7uf 4 qty
33uf 2 qty
Aeon Capacitors Audio
1.0uf 4 qty
2.2 uf 2 qty
3.3uf 10 qty
5.6uf 2 qty
12uf 8 qty
30uf 4 qty
47uf 2 qty
51uf 3 qty
100uf 2 qty
Poly Caps
.22uf 400vdc 28qty
.47uf 400vdc 7qty
1.0uf 400vdc 15qty
1.5uf 400vdc 17qty
2.2uf 250vdc 4qty
3.0uf 200vdc 1qty
5.0uf 100vdc 4qty
10.0uf 100vdc 4qty
10.0uf 220vdc 11qty
20.0uf 100vdc 11qty
20.0uf 200vdc 4qty
Mills Resistors, Dayton Gold, Aeon resistor, Xircon
Mills Resistors Audio 1% 12 watt
2.0 qty 2
2.5 qty 4
3.0 qty 2
5.0 qty 2
8.0 qty 4
10.0 qty 8
Aeon audio 1%
1.0 qty 2
2.0 qty 2
12.5 qty 2
20.0 qty 2
12 ?? maybe
Dayton audio 2% 10 watt
2.4 qty 4
3.3 qty 4
3.7 qty 4
4.3 qty 2
4.7 qty 8
6.5 qty 4
9.1 qty 4
10.0 qty 4
5.1 qty 4
XIRCON speaker sizes
All 10 watt
40 pieces
Coils Foil & Air Core THE
TILE IN THE PICTURES IS 6 inches for perspective
COILS Air Core
20 awg
.30mh 2 qty
18 awg
.10mh 10qty
.20mh 14 qty
.30mh 2 qty
.33mh 2 qty
.37mh 2 qty
.50mh 2 qty
.65mh 2 qty
16 awg
1.50mh 2qty
COILS Foil Coils
16 awg
.62mh qty 2
1.00mh qty2
1.3mh qty 2
14 awg
.68mh qty 2
1.00mh qty 2
4.70mh qty 2
12 awg
.22mh qty 2
.82mh qty 2
Iron Core Coils
3.0mh qty 2
5.0mh qty 2
