Prelude pre-amp with Dantimax stuff and chassis
For sale:
A balanced/unbalanced preamp containing te following items.
From Dantimax:
Control 2
C2Panel 1-2 Frontpanel type 1 (2 encoders)
RelVol 3 10K with Dale resistors
Input 2
Standby 1
You can find more information on the Dantimax website:
Dantimax (elektronik) - Kits
The pre-amp is a design form Sander Sassen called Prelude. It was published in one of the audiospecials from Elektor. This is a very good pre-amp. among the best I ever heard.
Chassis is a MODU Slimline 2U, cabinet with 10mm frontpanel, 350mm depth.
Front was CNC made by someone over here in the Netherlands who has a CNC machine.
The Dantimax items work fine with a remote control. The rotary encoder for switching input is not working properly (RC, as said, works fine).
There is also a slight humm. Probably a grounding matter.
Asking € 300,- ex. P&P
The pics:
Prelude schema 2 by jvdwal2008, on Flickr
Prelude schema by jvdwal2008, on Flickr
EL2E4793 by jvdwal2008, on Flickr
EL2E4795 by jvdwal2008, on Flickr
EL2E4794 by jvdwal2008, on Flickr
EL2E4799 by jvdwal2008, on Flickr
EL2E4798 by jvdwal2008, on Flickr
