Very Large, Very Heavy! Kepco Voltage Regulated Power supply perfect
for tube amp builders!!
Kepco 2400B. beautifully constructed. has dual 400V@150ma supplies
that can be run separate or in parallel for 300ma!! also has negative
0-150V @5ma supply and dual 6.3Vac supplies at 10+++++ amps
All oil filled caps, has 6550 pass regulator tubes. super super quiet
and stable supply. this is a lab grade supply. this is basically a dual version of the other supplies i recently sold.
But It weights 150lbs at least i would bet. toooooo Big to ship! this would have to go by truck and that would be very expensive. looking for someone in the Minnesota or surrounding area. willing to work something out for an interested party.
I still have this bad boy! Must sell, need the room, no reasonable offer refused. I think this is worth about $300 but forget the value, willing to sell to someone that has real interest.
It is full of vintage tungsol 6550's amperex bugle boy 12AX7's. some 5u4's and 5881's etc. loaded and ready to run. it works perfect!
may even consider a trade for:
phono pre-amp
phono pre-amp
