Hi Res 550mm Fresnel Lens Set, 15"x11" First Surface Mirror, 6.3" IR/UV Filter, More!
This week I have several amazing items for sale.
1) 15"x11" first (front) surface mirror 6mm thick on optical glass substrate, super low wavelength error and best possible reflectivity. This is a scientific grade mirror. It would be the best possible choice for folding DIY projector light paths. It will work with large widescreen LCD panels. Many other uses too. Brand new.
2) 550mm 3DLens Fresnel lens and 220mm 3Dlens Fresnel lens set. Perfect for large widescreen LCD projector panels. F550 features super fine groove pitch for amazing resolution, especially if you put it in front of your LCD. Brand new.
3) 6.3" 'Hot Mirror' (UV & IR filter) for use with your DIY projector light engine, to reflect the 'bad stuff' back toward the lamp and away from your LCD panel. Many other uses. Brand new.
4) THK and Del-Tron linear motion slides with ball bearings. Great for DIY CNC setups or robotics. New or like new.
5) Monster Cable Reference speaker cables (Z3 and Z2) and interconnect (M1000 Mk. III). Super high end cables for your stereo or home theater. Like new.
Best of all, everything starts at only $1 with no reserve, amazing deals await.
Go here to see it all: LINK
