I bought two of these in anticipation for my new ride but unfortunately I dont have enough space to use them. These are some of the most raved about sound quality subs around.
$330 shipped each or $630 shipped for both.
I have over 140 positive feedback on Ebay.. user name is Lethl_Zo6.
Here are the specs off their website:
Ultra high power aluminium coned subwoofers designed to accurately reproduce the lowest frequencies and compliment the SEAS Lotus components.
Features:
Rigid lightweight aluminium cones for fast transient response.
Oversize natural rubber surround for long cone excursion.
Spider integrated lead in wires eliminating tinsel lead vibration.
Rigid injection moulded metal basket with tough black textured finish.
Large high temperature voice coil wound on a kapton former.
High quality binding posts for heavy gauge speaker cables.
Subwoofers
SW300
Nominal impedance 4 OHMS
Sensitivity
(2,83v.1m) 92dB
Free air resonance 20Hz
Qms 13.69
Qes 0.35
Qts 0.34
Vas 123 L
Eff. Area (sq/cm) 480
Linear coil travel
27mm
(P-P)
Voice coil diameter 54mm
Magnet weight 5.8Kg
Total weight 7.1Kg
Power handling 500 W
Mounting cutout 278.5mm
Mounting depth 155mm
Rec. Enc. Size
Closed cabinet
flat response 37L
Rec. Enc. Size
Vented cabinet qb3. 64.4L
Features:
Subwoofers
SW300
Sensitivity
(2,83v.1m) 92dB
Qms 13.69
Qes 0.35
Qts 0.34
Vas 123 L
Linear coil travel
27mm
(P-P)
Magnet weight 5.8Kg
Total weight 7.1Kg
Rec. Enc. Size
Closed cabinet
flat response 37L
Rec. Enc. Size
