Hi there,
I have a pair of old norh wooden drum speakers that I no longer use. Since upgrading my other pair of norh drums, and building a pair of frugel horns, I simply have no further use for them.
I'm pondering replacing the front baffle and using them as a pair of sub enclosures -- just to provide a little bit of extra bottom end for DIY horns, but nothing too demanding as I'm not really a thumping bass freak. Otherwise they'll just be gathering dust.
The internal volume is around 13 litres, they have an opening at the back, although I could seal them.
Anyone think there would be any suitable drivers -- or tell me what things to look for in a driver spec? -- most designs I've searched seem to be much larger volumes.
thanks in advance!
thanks in advance!
and here is a side view of a similar model:
Thanks for the reply:
Yes, I would get a separate amp and would active filter it.
I also did a bit more searching, and downloaded a programme called aj sealed sub designer -- not sure I know what I'm doing, but most drivers in a similar size enclosure end up with an -3db point at around 75-80hz.
That's not very low, is it?
However, with this scanspeak driver i ended up with an F3 of 49hz in a 20 litre box ( I guess I could stuff the box to make it 'appear' slightly larger to the driver?)
Is that still a waste of time? How low do you all go???? (sorry, i'm new to subs )
I would try to go to the low 30's at least if you want it worth your time. I used a single 10" in 1 cu ft and with equalization I am in the mid to low 20s.
Tang Band has some good driver like the W8-740C and W6-1139SG which are intended for small ported boxes usually. You also may want to look at active equalization to obtain lower extension.
ocool_15 said:W8-740C and W6-1139SG
I use both. The 6.5 is a surprising driver for the frame size but is no match for the 8. That 8 is a little workhorse but is not shielded. The 8 is on sale now at PE.
6.5 is good for up to about 100 ft^2, the 8 will do 200 ft^2, when used in pairs. Both are happier with their own amp.
- Subwoofers
- converting unused drums into subs
